Kiss fc + xm20 problem
Sad
I am building my first quad, I have a strange behaviour.
When I plug the battery with the quad disarmed, motors 2 and 3 start spinning fast, motor 3 spin slow, motor 1 not spinning. If I arm the quad, only motor 1 seems to respond to commands.
If I change the configuration in kiss gui and deactivate oneshot 125, everything seems ok (even if I never tried to fly yet ).
I have not calibrated the escs yet, I've configure all escs one by one setting the min throttle to 1020 and max to 1980, plus setting two motor 'reverse'
Any suggestion?
Thanks Big Grin
I would start off by calibrating the ESCs with one shot125 activated in the Kiss FC. Here is a link to some useful information: https://oscarliang.com/kiss-fc-blheli-esc/
After escs calibration the problem disappear thanks.
Anyway in acro mod if I give half throttle and then back to 0, motors keep accelerating. This is not happening in level mode.
Shouldn't be the opposite? Is this behaviour normal?
  Help Problem with GEP-F411-35A AIO + VTX V1 Walksnail Adam0880 2 287 09-Mar-2024, 08:35 PM
Last Post: Adam0880
  Help Problem accessing the ESP8285 chip on MATEK FC F405 WTE remi.auge 2 202 05-Mar-2024, 12:49 PM
Last Post: remi.auge
  Issue "Mixer Mode Problem detected" need help Steven FPV 9 296 24-Jan-2024, 06:36 AM
Last Post: Steven FPV
  Diatone stack current sensor problem Myman 10 1,548 27-Dec-2023, 12:02 AM
Last Post: Birbal
  Help Matek 411 Wing BAROMETER problem capediablo83 0 135 19-Dec-2023, 04:15 PM
Last Post: capediablo83
