Threads: 1
Likes Received: 0 in 0 posts
Likes Given: 3
0 Hi Everyone,
Has anyone used M3 steel screws for their Kakute F7 FC? I have searched for literature on this particular FC but cannot find whether it will short it out or not, any guidance is appreciated.
Thanks!
Threads: 125
Likes Given: 99
388 The easiest way to check is use a DMM. On continuity mode, check if the metal ring around the mount holes are connected to the ground. If it is not, then you can use metal screws. If it is, then I would consider using nylon screws.
Threads: 674
Likes Received: 3,160 in 1,747 posts
Likes Given: 2,033
139 The metal ring around the screw hole is connected to ground (just like most FC out there).
It shouldn't cause a short using metal screws, but i would advice against it because it doesn't use rubber grommets.
For the Kakute F7, nylon hardware is better because it can take the impact in crashes, and break in extreme cases. With metal screws, the impact will completely pass on to the board and more likely to damage it.
Threads: 125
Likes Given: 99
388 Grounding to frame doesn't effect the quad. But now you made a bigger ground plane. Especially on crash or loose wire, there is a higher chance for short. I make it a habit to avoid it if I can.
Threads: 1
Likes Given: 3
0 Just saw this, thank you!
