Threads: 38
Likes Given: 430
118 What ELRS firmware version are you running?
Did you try updating the RX and TX with the latest ELRS firmware?
Threads: 76
Likes Received: 1,386 in 1,037 posts
Likes Given: 804
41 Maybe an issue with the receiver?
On mine when I power up the drone, it binds instantly to the radio. First time. You might want to take a look at the wiring on the FC, see if you can see any issues (bad joints, loose wires, etc). Since it does automatically bind eventually, it probably isn't an ELRS issue. Sounds more of a hardware issue, maybe a bad power wire, maybe a bad component on the receiver.
Try Not, Do or Do Not
- Yoda
Threads: 0
Likes Received: 0 in 0 posts
0 Just turn the transmiter BEFORE the receiver, if you turn on the quad before the radio it does take sometime(forever) to recognize the receiver
