Threads: 11
Likes Received: 0 in 0 posts
Likes Given: 15
0 Hi Guys,
I have a MATEKF405CTR and the altitude is showing inaccurate by +- 5 meters in the OSD.
Any ideas on how to solve this?
Thanks.
Threads: 582
Likes Received: 8,928 in 6,604 posts
Likes Given: 1,425
786 22-May-2020, 11:35 PM (This post was last modified: 22-May-2020, 11:36 PM by SnowLeopardFPV.) You can try putting a bit of foam over the hole in the barometer, but the bottom line is that I've found the barometer on flight controllers to be quite inaccurate. I have a Matek F405-STD and I just accepted that it will never give me a decent reading. Mine sometimes reads almost 10m when I'm just centimetres of the ground about to land. I gave up trying to get an accurate reading from it. If I arm the quad and just remain stationary on the ground I can actually watch the altitude height creep up bit by bit when my quad hasn't even moved a millimetre. I only really use it to give me a rough idea of how high I am and just subconsciously subtract ~10m from the actual reading.
Threads: 11
Likes Given: 15
0 22-May-2020, 11:42 PM (This post was last modified: 22-May-2020, 11:42 PM by lleston2.) Hi SL, i don’t know where that barometer is located on the board. Can you tell me?
