  • 1 Vote(s) - 5 Average
How to Lubricate brushless Motors - mini quad Quadcopters RC
[Image: IMAG0296.jpg]
In a brushless outrunner motor, the parts that generate friction is the shaft bearings. After some usage it might get dry and start making noise, lubricant can help improving the smoothness and efficiency.
https://oscarliang.com/oil-micro-brushless-motors/
Lubricating your motor bearings is an important part of motor maintenance and in the long run can lead to extended life. more flying == greater happiness Smile
Choosing the right oil/lubricant
Choosing the correct oil to use for your motors can be tricky if you don’t know what to look out for. You want to find an oil/lubricant that can handle parts moving at a high RPM, heavy-duty, high temperatures and humid environments. Knowing all of this you MUST NOT USE WD-40.
WD-40 is possibly one of the worst things you can put on your motor bearings. It is fantastic for applications such as freeing up hinges, locks, cleaning and rust-prevention but it is not marketed or sold as a lubricant.  lubricants must have good oxidation resistance to resist sludge build up at operating temperatures (in our case, this can be quite high) and most lubricants are formulated with antioxidant additives to provide this protection. However, WD40 does not contain such additives and would likely degrade to form sludge fairly rapidly.
A good choice of lubricant would be one that is specifically designed for the lubrication of high speed parts at higher temperatures. I’ve found that one of the best choices for this is Singer Super Oil which is a good cheap universal lubricant.
Singer super oil
This oil is specially formulated for lubricating sewing machines which have a lot of small fast moving parts that generate a lot of friction and heat. This oil is perfect for our application and can be found online for around $5 (£3) for 125ml.
Another alternative oil is the Tarot High-Speed Bearing Oil that can be found on banggood for about £7 (£5).
What parts to lubricate
Within the typical brush-less motor designed for use on a quadcopter, you will typically have 2 bearings. See below at the stator of a DYS 1806 and cobra 2204 motor, one bearing is on the top of the stator, and the other is on the bottom.
Top bearing on motor stator (Left is cobra 2204, right is DYS 1806).
Top bearing on stator
Bottom bearing on motor stator:
Bottom bearing on stator
These types of bearings are called shielded bearings and are designed to keep the majority of the grime and rubbish out of the bearing enclosure, unlike sealed bearings which are used on higher quality motors and keep everything out of the bearing enclosure.
Method
I tend to lubricate my motor bearings each week after heavy use, its best to do this after cleaning all the dirt off and out of your motors (crashing is a big part of 250 flying!) and I’ve discovered a little trick that I’ve found works really well.
Hypodermic Needle
You will need to get hold of a hypodermic syringe and rounded needle (or any needle, I prefer to not have sharp things with oil in them lying around on my desk!) for the application of the oil. You don’t need too much, just a few drops on each bearing and then spin the motors to make sure the application is even. Once done, I leave them for the night until I’m ready to fly again the next day! simple right?
How to reach inside motor
You can pick up a pack of hypodermic syringe and needles on ebay for a few $ Smile http://www.ebay.co.uk/itm/231080683351
Hi Oscar, that link you posted is broken,
[-] The following 1 user Likes quadfish's post:
  • dronepartsx
I use a small syringe with fine tipped needle and apply singer sewing machine oil to my bearings. Has worked really well , generally now when the bearing does get a bit too noisy I just ditch the motor and buy a new one. (which does not happen too often..I normally break the motor before a bearing fails..lol)
Too much time and effort to replace a bearing and maybe a shaft and c-clip. Just lube your bearings, Clean out your motors in the field with a can of compressed air.
  • dronepartsx
(05-Feb-2016, 04:59 AM)quadfish Wrote: Hi Oscar, that link you posted is broken,
yea... Alex's site is down...
Hey Oscar your image isn't working, not sure if thats because it was uploaded and the setting s have been changed now.
lol FPV
Ragg-e WBX 5"
BUILD
MY CHANNEL
(15-Feb-2016, 01:39 PM)dronehq Wrote: Hey Oscar your image isn't working, not sure if thats because it was uploaded and the setting s have been changed now.
the images were from Alex's website, but his site is now down so are the images. not much we can do unfortunately.
Something I was looking into today. I use Singer oil for my rc car bearings. Has there been any issues with bearing life on motors using Singer oil? I have new motors that I plan to disassemble to clean and lube as I don't really have faith in them being properly cleaned and lubed from the factory.
  How to clean drone motors mattyfleischfpv 4 862 26-Jan-2024, 01:25 PM
Last Post: mattyfleischfpv
  Tutorial DIY Mini Rotary Tool - Drill || Grinder || Cutter || Polisher || - A2212 1000KV Brush sim_tcr 1 810 24-Dec-2021, 03:51 PM
Last Post: iFly4rotors
  Mamba F405 Mini MK2 - GPS on Softserial fishbowlfpv 13 8,611 07-Jul-2021, 06:07 AM
Last Post: president_kang
  Ever wanted to smash the SH*T out of ur quad? Rob Axel 2 651 20-Mar-2021, 01:51 AM
Last Post: kafie1980
  how do i find my mini drone wtf3d 0 743 28-Feb-2021, 11:15 AM
Last Post: wtf3d
