[HELP] Omnibus f4 No response from USB only DFU
Hi can any one shy me light here please
I have received my Omnibus f4 Pro V2 yesterday.
Wired all turns on fine.
Checked board before wiring all worked fine Connected to Betaflight fine.
Then I come to Update firmware and board turn it self in DFU mode Did Erase then flash but its stuck on Flashing at full bar.
And don't do nothing
If I disconnect and reconnect I get no response from controller NOTHING COMES ON PC.
IF I press boot it turn in DFU mode but cant flash it it stuck on Flashing again.
Any one had this issue ???
Regards
Sorted
Full chip erase need to be unchecked to work
Regards
[-] The following 1 user Likes Darozas's post:
  • unseen
  Help No response flight controller with receiver Crazyart 1 244 09-Jan-2024, 12:53 AM
Last Post: Crazyart
Shocked Help FC always in DFU rockford007 5 1,895 25-Dec-2023, 04:38 PM
Last Post: slavikdr
  No betaflight connection with just USB aerokam 5 411 20-Oct-2023, 05:44 PM
  DFU Zadig and impulseRC zomer 1 388 09-Aug-2023, 04:23 PM
Last Post: voodoo614
  CRAZYBEE F4 PRO doe not get to DFU mode orangu 8 3,473 08-Aug-2023, 09:46 PM
Last Post: zomer
