05-Sep-2018, 10:09 AM
Here is complete components I am planning for,
X2 ELF 88mm
Original Airbot Omnibus F4 Nano V6
Hakrc 15A Blheli_S BB2 2-4S Dshot 4 In 1 ESC
HGLRC Super Mini 1.38g WS2812 Colorful LED w/ 5V Active Alarm Buzzer
4 Pairs Gemfan Hulkie 1940 1.9x4.0 PC 3-blade Propeller
4 PCS Eachine Prop Guard 1102 1103 1104 1105 Brushless Motor
Flysky FS-A8S
ORANGE 850mAH 2S 30C/60C (All 4 motors draw maximum 20A, lipo 0.85x30=25.5A. Is lipo ok for this build?)
As per sepcs from above components, its coming to 99.3g AUW (93.3g if I drop prop guards).
There is ORANGE 360MAH 2S 30C/60C as well, If I use that AUW is 78.3g. But that lipo 0.36x30=10.8A only. Wont that be an issue?
I am aiming for maximum fligt time rather than speed. In fact I prefer to fly slow.
I reviewed all x2 elf 88mm builds at https://rotorbuilds.com/part/11208 out of 22 builds, 10 are using 1104 7500KV.
I do have the option of buying Racerstar 1104 7000KV and 1103 8000KV.
As per specs, 1103 with 3s and 2030 prop it has 78g pull and 4.7A load current. 1103 is 3.7g and can take 1-3S
As per specs, 1104 with 2s and 3020 prop it has 95g pull and 4.1A load current. 1104 is 5.5g and can take 1-2S
Which one I should go for?
X2 ELF 88mm
Flysky FS-A8S
