16-Jun-2023, 12:27 AM
Full review: https://oscarliang.com/flywoo-1s-nano-ba...-dc16-fr16
CLI diff for Walksnail version (FR16):
CLI diff for Analog version (DC16):
defaults nosave
# Betaflight / STM32F411 (S411) 4.4.1 Apr 6 2023 / 04:23:14 (e43d591) MSP API: 1.45
# config: YES
# start the command batch
batch start
defaults nosave
board_name FLYWOOF411_5IN1_AIO
manufacturer_id FLWO
mcu_id 001b003b3032511935383938
signature
# name: FLYWOO
# resources
resource BEEPER 1 C14
resource MOTOR 1 B10
resource MOTOR 2 A08
resource MOTOR 3 B07
resource MOTOR 4 B06
resource PPM 1 A02
resource SERIAL_TX 1 A09
resource SERIAL_TX 2 A02
resource SERIAL_TX 11 B00
resource SERIAL_RX 1 A10
resource SERIAL_RX 2 A03
resource SERIAL_RX 11 B04
resource I2C_SCL 1 B08
resource I2C_SDA 1 B09
resource LED 1 C13
resource SPI_SCK 1 A05
resource SPI_SCK 2 B13
resource SPI_SCK 3 B03
resource SPI_MISO 1 A06
resource SPI_MISO 2 B14
resource SPI_MISO 3 B04
resource SPI_MOSI 1 A07
resource SPI_MOSI 2 B15
resource SPI_MOSI 3 B05
resource ADC_BATT 1 B01
resource ADC_CURR 1 A01
resource OSD_CS 1 B12
resource RX_SPI_CS 1 A15
resource RX_SPI_EXTI 1 B00
resource RX_SPI_BIND 1 B08
resource RX_SPI_LED 1 B09
resource GYRO_EXTI 1 B02
resource GYRO_CS 1 A04
resource USB_DETECT 1 C15
# timer
timer A02 AF3
# pin A02: TIM9 CH1 (AF3)
timer A08 AF1
# pin A08: TIM1 CH1 (AF1)
timer B03 AF1
# pin B03: TIM2 CH2 (AF1)
timer B10 AF1
# pin B10: TIM2 CH3 (AF1)
timer A15 AF1
# pin A15: TIM2 CH1 (AF1)
timer B06 AF2
# pin B06: TIM4 CH1 (AF2)
timer B07 AF2
# pin B07: TIM4 CH2 (AF2)
timer B00 AF2
# pin B00: TIM3 CH3 (AF2)
timer B04 AF2
# pin B04: TIM3 CH1 (AF2)
timer A00 AF2
# pin A00: TIM5 CH1 (AF2)
# dma
dma ADC 1 0
dma pin A08 1
# pin A08: DMA2 Stream 1 Channel 6
dma pin B03 0
dma pin B10 0
dma pin A15 0
dma pin B06 0
dma pin B07 0
dma pin B00 0
dma pin B04 0
dma pin A00 0
feature SOFTSERIAL
feature OSD
serial 0 131073 115200 57600 0 115200
aux 0 0 2 1350 2100 0 0
aux 1 2 2 1700 2100 0 0
# vtxtable
vtxtable bands 5
vtxtable channels 8
vtxtable band 3 BOSCAM_E E CUSTOM 5705 5685 5665 5645 5885 5905 5925 5945
vtxtable powerlevels 5
vtxtable powervalues 25 100 200 400 600
vtxtable powerlabels 25 50 100 150 200
# master
set gyro_lpf1_static_hz = 0
set gyro_lpf2_static_hz = 525
set dyn_notch_count = 0
set gyro_lpf1_dyn_min_hz = 262
set gyro_lpf1_dyn_max_hz = 525
set acc_calibration = -2,-48,-14,1
set mag_bustype = I2C
set mag_i2c_device = 1
set mag_hardware = NONE
set baro_bustype = I2C
set baro_i2c_device = 1
set baro_hardware = NONE
set serialrx_provider = CRSF
set rx_spi_protocol = FRSKY_D
set rx_spi_bus = 3
set dshot_idle_value = 2000
set dshot_burst = ON
set dshot_bidir = ON
set motor_poles = 12
set vbat_max_cell_voltage = 440
set vbat_warning_cell_voltage = 330
set current_meter = ADC
set battery_meter = ADC
set ibata_scale = 200
set beeper_inversion = ON
set beeper_od = OFF
set yaw_motors_reversed = ON
set pid_process_denom = 4
set simplified_gyro_filter_multiplier = 105
set osd_vbat_pos = 2307
set osd_rssi_pos = 195
set osd_link_quality_pos = 2211
set osd_rssi_dbm_pos = 163
set osd_tim_1_pos = 2390
set osd_tim_2_pos = 2422
set osd_flymode_pos = 2294
set osd_throttle_pos = 2326
set osd_current_pos = 2370
set osd_mah_drawn_pos = 2402
set osd_craft_name_pos = 2083
set osd_warnings_pos = 2442
set osd_avg_cell_voltage_pos = 2339
set osd_disarmed_pos = 2411
set osd_displayport_device = MSP
set osd_canvas_width = 30
set osd_canvas_height = 13
set system_hse_mhz = 8
set vtx_band = 1
set vtx_channel = 1
set vtx_power = 5
set vtx_freq = 5865
set max7456_spi_bus = 2
set frsky_spi_tx_id = 64,120,0
set frsky_spi_offset = -103
set gyro_1_bustype = SPI
set gyro_1_spibus = 1
set gyro_1_sensor_align = CW0FLIP
set gyro_1_align_pitch = 1800
set craft_name = FLYWOO
# profile 0
set dterm_lpf1_dyn_min_hz = 63
set dterm_lpf1_dyn_max_hz = 127
set dterm_lpf1_static_hz = 0
set dterm_lpf2_static_hz = 127
set vbat_sag_compensation = 100
set iterm_relax_cutoff = 25
set p_pitch = 74
set i_pitch = 133
set d_pitch = 45
set f_pitch = 151
set p_roll = 71
set i_roll = 127
set d_roll = 44
set f_roll = 145
set p_yaw = 71
set i_yaw = 127
set f_yaw = 145
set d_min_roll = 41
set d_min_pitch = 42
set d_max_advance = 0
set thrust_linear = 30
set feedforward_jitter_factor = 5
set simplified_master_multiplier = 110
set simplified_d_gain = 125
set simplified_pi_gain = 145
set simplified_dmax_gain = 25
set simplified_feedforward_gain = 110
set simplified_pitch_d_gain = 90
set simplified_dterm_filter_multiplier = 85
profile 1
profile 2
profile 3
# rateprofile 0
set rates_type = BETAFLIGHT
set roll_rc_rate = 108
set pitch_rc_rate = 108
set yaw_rc_rate = 100
set roll_srate = 73
set pitch_srate = 73
set yaw_srate = 70
rateprofile 1
rateprofile 2
rateprofile 3
# save configuration
defaults nosave
# config: YES
batch start
defaults nosave
mcu_id 0050000d3032511935383938
signature
# name: FLYWOO
# resources
feature -RX_SPI
feature SOFTSERIAL
feature TELEMETRY
serial 1 8192 115200 57600 0 115200
# vtxtable
vtxtable bands 5
vtxtable channels 8
# master
set acc_calibration = 8,69,101,1
set vtx_band = 3
set vtx_channel = 4
set vtx_power = 5
set vtx_freq = 5645
# profile 0
set p_pitch = 74
set i_pitch = 133
set d_pitch = 45
set f_pitch = 151
set p_roll = 71
set i_roll = 127
set d_roll = 44
set f_roll = 145
set p_yaw = 71
set i_yaw = 127
set f_yaw = 145
set d_min_roll = 41
profile 1
profile 2
profile 3
# rateprofile 0
set roll_srate = 73
set yaw_srate = 70
rateprofile 1
rateprofile 2
rateprofile 3
