12-Jan-2023, 04:03 PM
Good morning. I have an HM X12 that suddenly seems to be stuck in pit mode or something similar. This is a 'working one minute, not the next' type of thing. I re-flashed both BF and Quicksilver and the result is the same. VTX set to R8, 400mw, no pit mode enabled. The signal is fine until it gets 10 feet away then drops almost instantly. I've checked my goggles with another quad, and used that same known working antenna on the problem quad. Same signal issue.
Can the VTXs on these FCs just quit?
Thanks
Thanks
