Posts: 90 Threads: 31 Likes Received: 49 in 14 posts Likes Given: 92 Joined: May 2019 Reputation: 0 20-May-2019, 04:18 AM Hey all! I just received my Fatshark Recon V2 FPV goggles.. and I'm super bummed because I have to cross and refocus my eyes to see the screen properly.. I'm super dizzy after just using them for like 5 minutes. I have 20/20 vision, so I'm not sure if it's just me or if this is normal? I have had to adjust camera viewfinders and binoculars slightly differently than most people in the past.. Are there goggles that have complete adjustability? I know some of the Fatshark goggles (and others as well) have the ability to scooch the screens around.. you think those would be helpful to me? Thanks! -Ross • Posts: 12,098 Threads: 125 Likes Received: 3,739 in 2,836 posts Likes Given: 99 Joined: Feb 2017 Reputation: 388 Some people can't handle first person view and makes them dizzy. • Posts: 90 Threads: 31 Likes Received: 49 in 14 posts Likes Given: 92 Joined: May 2019 Reputation: 0 (20-May-2019, 05:16 AM)voodoo614 Wrote: Some people can't handle first person view and makes them dizzy. bummer! just sucks I can't try on a bunch of goggles before I buy • Posts: 12,098 Threads: 125 Likes Received: 3,739 in 2,836 posts Likes Given: 99 Joined: Feb 2017 Reputation: 388 20-May-2019, 06:07 AM (This post was last modified: 20-May-2019, 07:10 AM by voodoo614.) It is not likely the goggles. For example some people can read in the car while others can't. Or play FPS shooter. I have no problem with either. But I know friends who get nauseated. You can continue trying and you can probably train yourself to lessen the nausea. Posts: 1,013 Threads: 11 Likes Received: 452 in 349 posts Likes Given: 372 Joined: Dec 2017 Reputation: 16 Quote- "I have to cross and refocus my eyes to see the screen properly.." This part of your first post is what caught my eye, this isn't normal for most people who don't wear any corrective lenses. Eachine makes a box goggle that is adjustable I believe, and they do have the inexpensive EV100 slimline goggles with adjustable focus. In any case, your eyes should be fairly relaxed and easy to focus when everything is correct. Box goggles also have a large FOV compared to slimline goggles, so that could be contributing to your dizzyness. Posts: 3,533 Threads: 265 Likes Received: 2,610 in 1,545 posts Likes Given: 3,893 Joined: Feb 2018 Reputation: 78 I think Sugs may be onto something. If it turns out it is motion sickness, you may be able to reduce the sensation or stop it all together with medication. Meclizine, or Dramamine may help. Posts: 97 Threads: 16 Likes Received: 51 in 28 posts Likes Given: 27 Joined: Jun 2017 Reputation: 0 Try to sit down while flying that helps your brain from constant focus on your body. I had the same could not stand and fly felt drunk all the time.But on seat all this gone away.and after while when your brain get use to FPV I start standing and after while I wasn't need a seet now I fly fine without a seat Posts: 473 Threads: 105 Likes Received: 54 in 41 posts Likes Given: 33 Joined: Aug 2018 Reputation: 0 I too use box goggles eachine vr006 (cheapest) Initially i too was having dizziness and focusing problems. I used faceplate of cheap vr goggles over the goggles. Which resolved all my issues. Posts: 6,113 Threads: 172 Likes Received: 2,287 in 1,834 posts Likes Given: 4,737 Joined: Feb 2019 Reputation: 100 the ev200d is adjustable in two axis. ( i think the ev100 is only adjustable on one axis??) messuring your eyes quality, they should now how the goggle have to be for you, eyedistance.... or others - could be a reason. you could try it with an additional faceplate, or more, this would be a simple reason, if the distance is your problem. i now someone fly with an additional 3dprint for more distance between eyes and display. Posts: 90 Threads: 31 Likes Received: 49 in 14 posts Likes Given: 92 Joined: May 2019 Reputation: 0 20-May-2019, 06:24 PM (This post was last modified: 20-May-2019, 06:26 PM by rossmoney.) (20-May-2019, 06:07 AM)voodoo614 Wrote: It is not likely the goggles. For example some people can read in the car while others can't. Or play FPS shooter. I have no problem with either. But I know friends who get nauseated. You can continue trying and you can probably train yourself to lessen the nausea. thanks for the reply! I can read in the car and play FPS, so it may just be that I was standing and walking a little while wearing them (20-May-2019, 09:12 AM)Krohsis Wrote: I think Sugs may be onto something. If it turns out it is motion sickness, you may be able to reduce the sensation or stop it all together with medication. Meclizine, or Dramamine may help. Thanks! Hopefully it doesn't come to this.. but we'll see! (20-May-2019, 12:48 PM)Darozas Wrote: Try to sit down while flying that helps your brain from constant focus on your body. I had the same could not stand and fly felt drunk all the time.But on seat all this gone away.and after while when your brain get use to FPV I start standing and after while I wasn't need a seet now I fly fine without a seat This could definitely be it! rookie mistake, but I literally walked around my apartment with drone in hand and goggles on. I can see how that would totally mess with my head. I'll try sitting next time! • Posts: 21,330 Threads: 590 Likes Received: 9,001 in 6,662 posts Likes Given: 1,426 Joined: Jun 2018 Reputation: 790 (20-May-2019, 06:24 PM)rossmoney Wrote: I literally walked around my apartment with drone in hand and goggles on. I can see how that would totally mess with my head. I'll try sitting next time! Yes, walking around with goggles on definitely isn't going to help and is a very bad idea from the point of view of your own safety • Posts: 1,013 Threads: 11 Likes Received: 452 in 349 posts Likes Given: 372 Joined: Dec 2017 Reputation: 16 (20-May-2019, 06:17 PM)hugnosed_bat Wrote: the ev200d is adjustable in two axis. ( i think the ev100 is only adjustable on one axis??) It's the opposite. EV100 has IPD and focal length adjustment. EV200 only has IPD adjustment, but can use Fatshark diopters if necessary. @rossmoney, you could try firing up the goggles and just hold them to your face then slowly pull them farther away to see if the image gets clearer at a certain point. • Posts: 9 Threads: 1 Likes Received: 3 in 2 posts Likes Given: 1 Joined: May 2019 Reputation: 0 You need to sit down and not move you head when you are flying. Posts: 302 Threads: 46 Likes Received: 152 in 88 posts Likes Given: 61 Joined: Oct 2018 Reputation: 11 I had a similar issue with dizziness while learning Acro on a simulator. I could only do about 3 minutes at a time. Over a period of about 3-4 weeks or so I gradually increased my 'goggle time' until I didn't get dizzy. Other posts suggest to sit down. YES YES YES, sit down or at the very least lean against something so you will not move. As far as needing to refocus... I think that will need to be determined by you and whatever goggles you have. I started with the box goggles and could not focus (i wear reading glasses) because my glasses would not fit in the goggles. After some DIY fixes (mounting magnifiying lens from a jewelers head set )I was able to use the box goggles. Thankfully for me they stopped working which gave me a reason to go buy Fatsharks which worked very good for me out of the box. Good luck. Posts: 90 Threads: 31 Likes Received: 49 in 14 posts Likes Given: 92 Joined: May 2019 Reputation: 0 (21-May-2019, 12:34 PM)roger74 Wrote: I had a similar issue with dizziness while learning Acro on a simulator. I could only do about 3 minutes at a time. Over a period of about 3-4 weeks or so I gradually increased my 'goggle time' until I didn't get dizzy. Other posts suggest to sit down. YES YES YES, sit down or at the very least lean against something so you will not move. As far as needing to refocus... I think that will need to be determined by you and whatever goggles you have. I started with the box goggles and could not focus (i wear reading glasses) because my glasses would not fit in the goggles. After some DIY fixes (mounting magnifiying lens from a jewelers head set )I was able to use the box goggles. Thankfully for me they stopped working which gave me a reason to go buy Fatsharks which worked very good for me out of the box. Thanks for taking the time! I’m thinking of just taking a huge plunge and getting the HDO’s to future proof myself. Thanks for the tips! Good luck. • |
