Fried 5V Regulator on Tyro 119
Thank you for the detailed look at the picture I provided! I haven't messed around with the drone yet since your reply, and certainly interested in trying to clean things up and see where I can get. In the mean time, I wanted to respond and let you know about your observations:
12o'clock position. That's the one I was worried about due to the coloring, but if it's just flux, then great!
2o'clock position. You're right. That is the BEC. I did electricial tape the board itself, but looks like I should've taped the connections themselves. I bet you're right, and that's where the short occured.
7o'clock position. Haha. When I posted this photo, I thought the exact same thing: "Where is that motor wire?" Sure enough, it's just hidden well in the photo, and it IS connected from underneath.
9'oclock. Great to know about the temperature. I think I should probably just invest in one of those soldering practice boards, and give it a go for a while. I have a lot to learn with soldering!
I'll report back after I clean things up a bit, and attempt one or two more power ups!
[-] The following 1 user Likes Radioactrev's post:
  • Lemonyleprosy
Solder practice boards are great.
When you go back in to clean things up, take a good look at the other side of your esc in that 2 o’clock position to make sure that that positive cable didn’t obviously damage anything.
If after cleaning everything up and checking for shorts, it won’t power up again- try replacing the bec first.
Dangerous operations.
  Fried vtx spark 2 428 23-Feb-2022, 05:49 PM
Last Post: romangpro
  Fried Caddx Vista Troubleshooting? woodzi123 3 1,807 30-Jan-2022, 11:54 PM
Last Post: V-22
  New FC fried when connected to USB nuron 2 708 21-Nov-2021, 12:23 AM
Last Post: nuron
  TRYO-119 HELP No Stick Movement HELP organic 25 1,680 26-Oct-2020, 09:10 PM
Last Post: organic
Sad Smoking vtx [probably fried beyond repair] Superflim 6 2,043 13-Aug-2020, 12:45 PM
