20-Nov-2021, 09:09 PM
Hey folks,
today I installed a new flight controller, checked everything for continuity, plugged in the lipo with a smokestopper in between and was satisfied with myself not to have produced a short circuit. Then I wanted to configure the FC in betaflight, plugged in the USB, got a few blinking LEDs, but before betaflight connected, there was some weird smell and the LEDs went out. I then unplugged the FC and found continuity between ground, 4.5V and 3.3V. The RX that was connected to this port is fine, or at least has no continuity. There also is no continuity between 5V and ground on the FC, so I suspect some voltage regulator that is driven by USB only is burned through. Is it possible that I missed something in my procedure and destroyed the FC by faulty installation or can I expect to have gotten a faulty unit? I hope I can return it, not sure because I obviously soldered to it already, if I can not return it, is it possible to replace the faulty voltage regulator?
