i am a beginner so,sorry if it is a dumb question! I have a cloned sp3 racing(acro) fc.I flashed it with latest cleanflight firmware and done some settings like gyro,motor,esc calibration with micro usb.but when i connet 5v DC to vbat connection,noting happened no LEDs blinks.I checked power supply and connectors also.and when i checked voltage in UART1,3 or any GND,VCC port,there is no output voltage in FC.however flight controller is working in usb mode.I also could not configure PPM/PWM.So, any one can guess that what happened to my fc.
Flight controller is not working! |
23-Jan-2017, 12:15 PM Vbat is designed to measure voltage from battery, not to power the board. Connect your 5v wire to any 5v pin on the board. Find me on Youtube and Instagram. I currently fly: DRC Aura, NOX5R, Minimalist 112 and drive a scrap RC car 23-Jan-2017, 05:00 PM First,thanks for reply! I thought vbat is for 5v supply from battery for flight controller .OK please suggest me where to connect 5v voltage supply. 23-Jan-2017, 05:31 PM Easiest way is where you have your motors connected on pins M1-M4, just connect your 5V supply to M5 pins 23-Jan-2017, 05:32 PM 24-Jan-2017, 03:23 AM One confusion! I want to connect ppm in receiver so, in which I have to connect the ppm wire and I have to also connect 5v voltage to receiver? 24-Jan-2017, 04:56 AM (24-Jan-2017, 03:23 AM)ANUJ300 Wrote: One confusion! I want to connect ppm in receiver so, in which I have to connect the ppm wire and I have to also connect 5v voltage to receiver? Yes it has to be powered too but there's another 5V/GND next to the ppm pin (see sloscotty's pic, left side). That's where those 3 wires from your pic go. 24-Jan-2017, 04:59 AM Correct. Your flight controller is powered by a 5 volt power supply. When you connect the 3 wire cable to your receiver, it's receiving power from the flight controller. 24-Jan-2017, 06:25 PM ok! clear but here is another problem-Cleanflight is not showing any stick movement(like roll,pitch,yaw..) during PPM,PWM or SBUS setup. I've enabled the correct protocol - PWM or PPM and wired it correctly.I'm giving a picture of PPM setup. 24-Jan-2017, 06:43 PM That receiver isn't PPM compatible. Just PWM 24-Jan-2017, 07:04 PM 24-Jan-2017, 09:08 PM (24-Jan-2017, 07:04 PM)ANUJ300 Wrote: Only PWM? What iF I change the receiver to this-http://m.banggood.com/Flysky-FS-A8S-2_4G-8CH-Mini-Receiver-with-PPM-i-BUS-SBUS-Output-p-1092861.html You'll have to research to make sure it's compatible with your transmitter and if so yes, this is what you need as the F3 EVO isn't PWM compatible. Isn't this hobby fun! (24-Jan-2017, 09:08 PM)RENOV8R Wrote: You'll have to research to make sure it's compatible with your transmitter and if so yes, this is what you need as the F3 EVO isn't PWM compatible. Isn't this hobby fun! No need for research, A8S is not AFHDS compatible, only AFHDS 2A (FS/TGY i6, i6s, i6x, tgy evolution). I tested it for a friend, it disconnects as soon as I switch my i6 to older version of protocol. EDIT I'm assuming he has the FS 9x judging only by this monstrous RX Find me on Youtube and Instagram. I currently fly: DRC Aura, NOX5R, Minimalist 112 and drive a scrap RC car 26-Jan-2017, 08:55 AM (24-Jan-2017, 09:58 PM)KonradS Wrote: No need for research, A8S is not AFHDS compatible, only AFHDS 2A (FS/TGY i6, i6s, i6x, tgy evolution). hey thanks for help I successfully configured to PWM.Let it check- channel1-AILE channel2-ELEV channel3-THRO channel4-RUDD channel5-AUX1 channel6-AUX2 channel7-AUX3 channel8-AUX4 Correct? |
JHEMCU GHF745 HD AIO F7 OSD Flight Controller and Built-In 40A BLHeli32 3-6S FC | husafreak | 0 | 87 | 05-May-2024, 01:11 AM Last Post: husafreak | |
Help No response flight controller with receiver | Crazyart | 1 | 263 | 09-Jan-2024, 12:53 AM Last Post: Crazyart | |
MAG sesnor on GPS M181 Walksnail not working on Mark 4/5 | marcinknd | 7 | 451 | 20-Nov-2023, 01:38 PM Last Post: SnowLeopardFPV | |
BetaFPV F4 FR 2S flight controller issues. | itsmerandy | 30 | 1,787 | 02-Nov-2023, 09:01 AM Last Post: SnowLeopardFPV | |
Help Mamba F405 Motor 3 not working when LED added | Toppers | 20 | 3,610 | 01-Nov-2023, 10:21 PM Last Post: onesimos |
