Flight Controller (FC) buzzing, humming high pitch noise sound
Hi all, i just starting this hobby, so i decided bought a second hand cinelog35 analog and i tested for a few flight it's fine except the VTX, it keep losing image in short range, so i disassemble and found out the VTX connector from FC is bending towards to other pin, after fixing the bending pin i clean the FC with brush, I plug in the battery it sound normal (beep beep beepp, beeep beeep) but i heard a humming noise, high pitch sound, buzzing noise, but everything seems normal, i test the motor, the VTX and beeper.
I also unsolder the vtx cable it still the same, the noise sound still there
did anyone have this problem before ?
I'm using geprc f722 aio 45a, here i attached the board
the sound is exactly like on this video
https://youtu.be/Mj9gDvPj0L8?t=54
I just put a reply in your other thread for the same problem at the link below...
https://intofpv.com/t-need-help-fixing-b...#pid202910
  FC roll and pitch axis are changed cele_FPV 1 89 02-Feb-2024, 05:17 PM
  Help No response flight controller with receiver Crazyart 1 246 09-Jan-2024, 12:53 AM
Last Post: Crazyart
  BetaFPV F4 FR 2S flight controller issues. itsmerandy 30 1,704 02-Nov-2023, 09:01 AM
  Radiolink Crossflight controller NHSA 7 931 07-Oct-2023, 06:44 PM
  Help JHEMCU GF16 F405 Flight Controller sdellava 4 1,734 25-Aug-2023, 08:57 AM
Last Post: PDK
