First build, having some trouble with tuning, any help appreciated.
Got into the hobby a couple of months back, I do have a decent amount of CP helicopter experience from back in the day and whilst this experience definitely translates when it comes to control, it does not at all when it comes to tuning.
I started out with a tiny whoop, and hopped into a BNF Mark 5 which flies fantastic. But I always loved building my heli's, so I figured I may as well build a quad, figured it'd be a good learning experience for when I inevitably begin being riskier and crashing.
So I built up a 6S, went with the following:
  • Volador II (X config)
  • Speedybee f405 v3 stack
  • Velox 2207.5 1950kv motors
  • Betafpv Nano ELRS RX
  • O3 Unit
Build went smooth, had a few hiccups during betaflight setup but over-all no issues, everything seems to work and I got everything updated to the latest. ESC's flashed to Bluejay to enable dshot & rpm filtering.
FC itself has been flashed to 4.4.2, and ELRS is on 3.3. Figured since everyone recommends to go with the Supafly tunes, that I'd try one of those out. So I loaded up the 5" tune, adjusted it based on my battery/motor specs (as suggested on their site).
Went to go for my maiden flight, and it flies, but like shit if I'm being honest. I'm assuming it's tune related, it definitely sounds tune related. On any yaw/pitch I'm getting what I can only describe as a chirpy, grinding noise followed by oscillations, I recorded a short video demonstrating this: https://www.youtube.com/watch?v=k0gVk1YEjzU
Motors come down, very warm, way too hot for just simply hovering around for ~30 seconds.
I've already started to dive into the JB series for PID tuning, from the research I've done so far it seems to be related to D-Term being too high (although I could be wrong). I've attempted nudging this down by from 1.3 down to 1.2, down to 1.1.
On a side note, I also tested with a completely stock betaflight profile (non supafly tune), thinking that maybe starting off completely from scratch maybe easier, however the flight characteristics were essentially identical.
Hoping someone with more knowledge than me can help me narrow this, otherwise I'll be watching videos for the next few hours which isn't a big deal either Smile
BF std should be very close to correct with no mods.
Check the motors for free rotation, tight to frame, tight props, and especially for motor screws not getting into windings.
DShot 300??
(22-Aug-2023, 09:01 PM)BadRaven Wrote: DShot 300??
Yep running Dshot300, props tight, frames tight. Double checked motor screw lengths to ensure there is nothing getting caught up in the windings. All 4 motors spin freely.
Figured I'd post an update incase anyone ran into the same issue. Went ahead and just completely reset everything back to stock betaflight 4.4.2, seems to have solved the problem. Only got to hover around a park and do a couple of test throttle pumps but noise is gone, oscillations seems to be gone as well and motors came down much cooler.
  Who wants to help me to build my first FPV? Several questions and concerns about how phelipems 3 105 13-Apr-2024, 12:09 AM
  First Build - prevent antenna chop? JohnnyCornRocket 5 203 28-Mar-2024, 02:16 PM
Last Post: iFly4rotors
  Best Battery Option for Build - Begginer Arkadius27 7 233 19-Mar-2024, 04:40 PM
  Where do I start PID tuning this quad? relentlesstech 15 336 17-Mar-2024, 05:22 PM
Sad What to check for short in a build? Yesnok 1 144 03-Mar-2024, 12:06 PM
