f1fc (naze) wont arm
hi my board wont arm after a nasty crash, the Accelerometer seems dead i tried to disable it with the "set acc_hardware=none" command but for some reason it wont let me arm.
i have checked my radio is inside the ranges, and i have set the "set small_angle=180" as suggested by someone so that i would be able to arm at any angle.
am i missing something, or did the flightcontroller die?
sorry for the newbie question : )
Dont be sorry friend! These guys love to help and acknowledged the fact that we all start at the same place! Unfortunately I too am noob status when it comes to this lol. So I'm going to learn with you Wink
I'm sure one of the many experts will be along shortly with a shiny gem of advice! Big Grin
The Obsession IS Real!
You say it won't arm.....you sure you've got power to the board?  If you know there is power to it, does it beep three times when you set it on a level surface (indicates the gyro has calibrated)?
(26-Jan-2017, 06:33 PM)sirdude Wrote: You say it won't arm.....you sure you've got power to the board?  If you know there is power to it, does it beep three times when you set it on a level surface (indicates the gyro has calibrated)?
there is power, i can run the motors from the tab, and everything seems to work as it used to telemetry etc. i dont have a beeper on it, the green led keeps blinking indicating it  hasent calibrated? dunno.
Could it be the gyro is broken? If it can't initialize properly, you can't arm i think.
Not sure there is a command to run gyro test from CLI... ?
Does the receiver tab in Clean/BetaFlight indicate proper motion and range when you move your sticks? You might also try to arm with failsafe disabled. For some reason, I am suspecting a receiver problem.
(26-Jan-2017, 07:29 PM)sloscotty Wrote: Does the receiver tab in Clean/BetaFlight indicate proper motion and range when you move your sticks?  You might also try to arm with failsafe disabled.  For some reason, I am suspecting a receiver problem.
yep sticks move fine and range is also within range, havent tried without failsafe.
okay gyro seems dead, in the sensor tab the gyro just flatlines Sad
That means your gyro is probably dead. You can try smacking the board against a table, maybe that makes it work again (no kidding, that fixed my phone's gyro)
Smile Help Omnibus f4 sd won't arm Omnibusf4sd.5inch 9 535 06-Apr-2023, 08:31 AM
Last Post: Omnibusf4sd.5inch
  Help Quad flipping on ARM mivo_ 16 869 28-Jul-2022, 10:08 AM
Last Post: kafie1980
  Mamba F405 MKII wont arm after adding LEDs - BOOTGRACE ERROR foxandthehen 3 378 03-Jun-2022, 01:06 AM
  Solved NAZE 32 isn't detected by BF or CF Ryan O. 3 359 12-May-2022, 01:16 AM
Last Post: the.ronin
  Help i cant arm a conspiracy 220 afixity 8 667 11-Nov-2021, 05:46 AM
Last Post: afixity
