Threads: 18
Likes Received: 69 in 48 posts
Likes Given: 33
9 If you go to "Flash BLHeli" then you see current with a name, something like racestar maybe, do you see that exact same name also in the drop-down list?
Threads: 10
Likes Received: 3 in 2 posts
Likes Given: 19
1 I will check into that as soon as i get home from work. Thanks
Threads: 18
Likes Given: 33
9 Is the configurator still in developing status or is it already reliable enough to use it for everyone?
Threads: 10
Likes Given: 19
1 Thanks I'll check out the blheli configurator
Threads: 10
Likes Given: 19
1 I flashed AH20 16.4 on my ESCs using blheli configurator without an issue. I havent yet to test fly after the flash though but everything seems ok. Ill update.
Threads: 18
Likes Given: 33
9 Good to hear that you successfully updated your ESC's, good luck with the flying.
Threads: 56
Likes Received: 335 in 196 posts
Likes Given: 183
15 After flashing ENSURE the settings are correct and that they haven't been overwritten by defaults (happens sometimes)
All the best
Grzesiek (Grisha/ Greg)
Curently flyable: Nox 5, Minimalist 112
Bench / in progres: fixing Nox 3, Scrap
thinking about building: 450
Threads: 2
Likes Received: 66 in 45 posts
Likes Given: 27
17 BLHeli Configurator always migrates settings using a smart algorithm.
Threads: 56
Likes Given: 183
15 As Andry said it is covered by smart algorithm... last weekend i've seen drop of the settings in other component, now im over sensitive and tripple checking if everything is in place
All the best
Threads: 56
Likes Given: 183
15 they should all show in synch (if you switched the cable in the motors) remaining settings should be in line everywhere
also have you seen this
All the best
