esc firmware issue
Question
Hey guys. Im looking for some help with my escs. I got racerstar 35amp escs from banggood and i got them soldered up to my quad. I went into blehi suite to flash the lastest firmware. It connected fine and showed they had 16.3. On banggoods website it shows to flash AH20 16.4 but in the list of the firmware it doesnt show that one. I was going to use AL20 16.4 but it gave and error that could cause a problem to flash a firmware version so i didnt flash anything to avoid messing anything up. Any suggestions. The escs work though i calibrated and everything works fine otherwise.  Here is a link of the escs i have.
http://www.banggood.com/4X-Racerstar-MS-...mds=search
If you go to "Flash BLHeli" then you see current with a name, something like racestar maybe, do you see that exact same name also in the drop-down list?
I will check into that as soon as i get home from work. Thanks
Try BLHeli Configurator, it's easier for flashing Smile
https://oscarliang.com/blheli-configurator-chrome-app/
  • Robocog
Is the configurator still in developing status or is it already reliable enough to use it for everyone?
Thanks I'll check out the blheli configurator
I flashed AH20 16.4 on my ESCs using blheli configurator without an issue. I havent yet to test fly after the flash though but everything seems ok. Ill update.
Good to hear that you successfully updated your ESC's, good luck with the flying.
After flashing ENSURE the settings are correct and that they haven't been overwritten by defaults (happens sometimes)
All the best
Grzesiek (Grisha/ Greg)
thinking about building: 450
BLHeli Configurator always migrates settings using a smart algorithm.
[-] The following 2 users Like AndreyM's post:
  • Grisha0, sloscotty
(01-Dec-2016, 10:52 AM)Grisha0 Wrote: After flashing ENSURE the settings are correct and that they haven't been overwritten by defaults (happens sometimes)
I think they are good i hooked it back up to blheli configurator and its shows its AH20 16.4 it was showing AH20 16.3 before the flash. So i think its ok. Ill get a screen shot when i get home and post it.
As Andry said it is covered by smart algorithm... last weekend i've seen drop of the settings in other component, now im over sensitive and tripple checking if everything is in place Smile
All the best
(02-Dec-2016, 12:24 AM)Grisha0 Wrote: As Andry said it is covered by smart algorithm... last weekend i've seen drop of the settings in other component, now im over sensitive and tripple checking if everything is in place Smile
Ok hopfully its ok. Do you think there could be a problem now with my firmware on my escs?
they should all show in synch (if you switched the cable in the motors) remaining settings should be in line everywhere
also have you seen this
All the best
(02-Dec-2016, 01:00 AM)Grisha0 Wrote: they should all show in synch (if you switched the cable in the motors) remaining settings should be in line everywhere
Thanks for this video. I wish i would found this when i tried using blheli suite at first. Ill double check and make sure everything is ok when i can Im at work yet. But i remember every is the same but ill check again to be sure. And i did swap the wires on my motors so i wouldnt have the change the motor direction in blheli. If there is a problem should i use bheli suite and flash this way instead then?
  Should you update firmware? Rob Axel 19 448 30-Apr-2024, 12:38 PM
Question Is it possible to test if an ESC works without soldering? HypnoToad 2 154 23-Mar-2024, 07:22 PM
Last Post: HypnoToad
  VTX issue - ATOMRC hurricane 5 bar1 1 183 10-Mar-2024, 12:36 PM
Exclamation Noob Question..... "VTX/ESC" Boards.... Coleon 12 361 02-Mar-2024, 12:35 PM
Last Post: Luk5569
Video Troubleshooting motor issue - I'm stuck, help! doraymon 7 320 25-Feb-2024, 05:48 PM
