Threads: 50
Likes Received: 704 in 450 posts
Likes Given: 1,189
30 When you say "increasing min throttle up to 1100" do you mean min throttle? Or the equivalent of digital idle which would be 10 i think?
Not that it matters since you tested multishot too.
Threads: 66
Likes Received: 350 in 248 posts
Likes Given: 164
34 Exactly. I stopped at 7 when using dshot and changed to multishot instead and increased it untill I reached 1100. Then I figured it wasn't any use going higher
Threads: 66
Likes Given: 164
34 Today I finally got some time to further troubleshoot this issue, and by reducing the looptime to 4k/4k, the problem went away. I thought that the xracer v3.1 was able to run 8k without issues?
Threads: 673
Likes Received: 3,156 in 1,744 posts
Likes Given: 2,032
139 what's your CPU usage under 8K and 4k?
Threads: 66
Likes Given: 164
34 27% and 7% without accelerometer
Threads: 66
Likes Given: 164
34 Yep, tried 32k, 16k, same as pid loop, dshot150,300,600. The only thing that fixed it was lowering the looptime. Haven't tried flashing new fw though...
Threads: 50
Likes Given: 1,189
30 Any chance it had to do with wether you were logging or not?
Threads: 0
Likes Received: 0 in 0 posts
Likes Given: 1
0 I know it's 5 years old thread. Want to confirm again, you solve that issue by lowering PID loop time? Thanks!
