Posts: 29 Threads: 7 Likes Received: 6 in 5 posts Likes Given: 8 Joined: Mar 2022 Reputation: 0 06-Mar-2022, 11:17 PM (This post was last modified: 06-Mar-2022, 11:17 PM by versus.) Hi everyone, First, sorry if this thread is not under "news & trending" category, as I am relatively new to FPV hobby and to this forum. Btw, I am curious if there is existing solution for optimizing VTX power to adapt to RSSI signal strength, and to turns off when its on idle. (I am worried about temperature of my Zeus Nano 350mW VTX when its just sitting on idle and tweaking my Betaflight settings around). • Posts: 4,073 Threads: 75 Likes Received: 2,548 in 1,858 posts Likes Given: 3,949 Joined: May 2021 Reputation: 121 07-Mar-2022, 12:27 AM (This post was last modified: 07-Mar-2022, 12:30 AM by Lemonyleprosy.) In the CLI in betaflight, enter this: set vtx_low_power_disarm = on save It’ll put your vtx into low power mode whenever it’s unarmed (such as when it’s on the bench). I’d still keep a fan blowing on it though. Dangerous operations. Disclaimer: I don’t know wtf I’m talking about. I wish I could get the smell of burnt electronics out of my nose. Posts: 29 Threads: 7 Likes Received: 6 in 5 posts Likes Given: 8 Joined: Mar 2022 Reputation: 0 07-Mar-2022, 12:35 AM (This post was last modified: 07-Mar-2022, 12:38 AM by versus.) (07-Mar-2022, 12:27 AM)Lemonyleprosy Wrote: In the CLI in betaflight, enter this: set vtx_low_power_disarm = on save It’ll put your vtx into low power mode whenever it’s unarmed (such as when it’s on the bench). I’d still keep a fan blowing on it though. By low power mode do you mean minimum of 25mW, because mine is already set on 25mW and still heating a lot when idling on bench. Either way, I think that dynamic power based on RSSI signal would be great for long range but racing as well (for interference) • Posts: 4,073 Threads: 75 Likes Received: 2,548 in 1,858 posts Likes Given: 3,949 Joined: May 2021 Reputation: 121 07-Mar-2022, 12:50 AM (This post was last modified: 07-Mar-2022, 12:52 AM by Lemonyleprosy.) It’ll drop it down to the lowest output power, which is usually 25mw- so yeah, it won’t help you. This would allow you to turn off the vtx at will: https://tinysleds.com/products/realpit-vtx-power-switch Dynamic power would be nifty. Edit- it looks like there was some discussion of dynamic vtx power in 2018, but it doesn’t look like anything came of it: https://github.com/betaflight/betaflight/issues/6756 Dangerous operations. Disclaimer: I don’t know wtf I’m talking about. I wish I could get the smell of burnt electronics out of my nose. • Posts: 21,189 Threads: 582 Likes Received: 8,930 in 6,606 posts Likes Given: 1,425 Joined: Jun 2018 Reputation: 786 You can implement dynamic VTX power if you run TBS Crossfire / Tracer and you have a TBS Fusion module. The Fusion module monitors the RSSI of the video signal and then communicates with the Crossfire / Tracer module (via Wifi) and sends VTX power level commands over-the-air via the Crossfire / Tracer RC link that instructs the VTX power to be either increased or decreased as required. I've never tried the feature myself. I just know that it exists. Posts: 4,550 Threads: 38 Likes Received: 1,245 in 1,064 posts Likes Given: 430 Joined: Aug 2020 Reputation: 118 As long as the quad is moving the vtx will stay cool with the airflow. Even 25mW gets hot on the bench. I do have pit mode and power levels on a switch but only use that during testing or setup. 99% of the time I just crank it up to full power and fly. Dynamic VTX power is a great feature but I just don't see many folks using it. Posts: 29 Threads: 7 Likes Received: 6 in 5 posts Likes Given: 8 Joined: Mar 2022 Reputation: 0 07-Mar-2022, 06:48 AM (This post was last modified: 07-Mar-2022, 07:01 AM by versus.) (07-Mar-2022, 01:19 AM)SnowLeopardFPV Wrote: You can implement dynamic VTX power if you run TBS Crossfire / Tracer and you have a TBS Fusion module. The Fusion module monitors the RSSI of the video signal and then communicates with the Crossfire / Tracer module (via Wifi) and sends VTX power level commands over-the-air via the Crossfire / Tracer RC link that instructs the VTX power to be either increased or decreased as required. I've never tried the feature myself. I just know that it exists. Glad to hear that! I use ExpressLRS and Steadyview/RapidMix on my Cobra X V2. There is ExpressLRS - Dynamic power for TX, and I've heard something about ELRS backpack which does WiFi communication with eg. VRX, but I don't know any details about it, if it supports VTX power control at all and how it works completely. • Posts: 29 Threads: 7 Likes Received: 6 in 5 posts Likes Given: 8 Joined: Mar 2022 Reputation: 0 (07-Mar-2022, 05:10 AM)kafie1980 Wrote: As long as the quad is moving the vtx will stay cool with the airflow. Even 25mW gets hot on the bench. I do have pit mode and power levels on a switch but only use that during testing or setup. 99% of the time I just crank it up to full power and fly. Dynamic VTX power is a great feature but I just don't see many folks using it. I thought it would be nice to: 0mW - disarmed - idle 25mW - armed - strong signal 100mW - medium signal 250+mW - low signal • Posts: 55 Threads: 3 Likes Received: 29 in 23 posts Likes Given: 6 Joined: Jan 2021 Reputation: 3 VTX performance can be easily assigned to a pot or switch. Including complete shutdown thanks to FET switch. If you have a TX with openTx / edgeTx you can program in logic functions, change based on the strength of the RSSI. I read somewhere that this operation through smartports overloads the FC CPU and in a critical case can lead to the machine crashing. It was described by people who fly, for example, in the woods, etc., here the declines in the power of RSSI are common. Yes, in both open and edge, it can include a time constant in the decision-making process. Therefore, each pilot will have to agree on his circumstances. • Posts: 4,550 Threads: 38 Likes Received: 1,245 in 1,064 posts Likes Given: 430 Joined: Aug 2020 Reputation: 118 I personally think ELRS backpack or OpenTX/EdgeTX is not going to be able to do what the Fusion/Crossfire ecosystem does in terms of dynamic vtx power. RC link RSSI is not effectively the same as Video link RSSI. ELRS backpack is only a wifi based SPI control for the VRX and basically helps switch band/channel similar to manual button pressing. Furthermore none of the VRX’s modules provide RSSI data over any of the module pins. • Posts: 55 Threads: 3 Likes Received: 29 in 23 posts Likes Given: 6 Joined: Jan 2021 Reputation: 3 Yes, thanks to ESP chips for Wifi update, a side benefit has opened up. Just as FC controls VTX (vtx table) via smartport, ELRS controls other devices such as VRX through backpacks. I think it's too young a concept, and we'll see a lot of more features. Similar to a bluetooth joystick or somewhere I have already seen access directly to betaflight through the wifi module in RX. • Posts: 932 Threads: 49 Likes Received: 192 in 157 posts Likes Given: 186 Joined: Jul 2020 Reputation: 11 I use a small personal desk fan. It keeps everything cool while sitting on the desk. Never had an overheating problem and simply just works. Posts: 4,550 Threads: 38 Likes Received: 1,245 in 1,064 posts Likes Given: 430 Joined: Aug 2020 Reputation: 118 How will the ELRS backpack enable dynamic power on VRX’s that do not provide access to the RSSI data that the VRX is sensing? The only published documentation we have where we can get VRX RSSI is for the RapidFire module with details on the SPI programming: https://www.immersionrc.com/?download=5995 • Posts: 55 Threads: 3 Likes Received: 29 in 23 posts Likes Given: 6 Joined: Jan 2021 Reputation: 3 I personally became interested in FPV a short time before ELRS was born. And that is a relatively short time. How far everything has changed in such a short time. Now there is a backpack with one-way SPI communication to the RTC6715 module. In my opinion, it's just a matter of time (my personal estimate, in the summer). Someone will create their own firmware with feedback or create an escape channel for RSSI.It will then send it back. Yes, at this point the ESP module only blindly sends an SPI command to change the frequency and band. You know, I'm just a relatively stupid person, but I still managed to understand how it all worked, and I'm pretty sure this modification will be born. The developers behind this all are miles away with their capabilities. I see only one reason why it couldn't happen, and that is if someone says it's useless. • Posts: 21,189 Threads: 582 Likes Received: 8,930 in 6,606 posts Likes Given: 1,425 Joined: Jun 2018 Reputation: 786 07-Mar-2022, 02:54 PM (This post was last modified: 07-Mar-2022, 02:55 PM by SnowLeopardFPV.) The one thing that might not make it worthwhile for the ELRS devs to invest any time or effort in dynamic VTX power switching via backpack is because people seem to be moving away from analogue systems to digital, so the demand for such a feature will be diminishing by the day. The reason TBS have done it is because they are also heavily invested in the analogue VTX market with their own products, so it made sense and would have likely been fairly trivial for them to implement something using their own existing analogue hardware with it's WiFi capabilities. ExpressLRS has nothing to gain IMO by spending time (or wasting time) on dying analogue systems when they would be better off spending that time on other more worthwhile / desirable features for ELRS. • |
