Threads: 18
Likes Received: 2 in 1 posts
Likes Given: 16
0 I am asking this because I need to mount the FC about 3 mm away from the center of the quad so that the USB will not be obstructed by the frame. Will that be OK ? I believe the accelerometers / gyros may not be mounted at the center of the FC board anyway.
Threads: 49
Likes Received: 192 in 157 posts
Likes Given: 186
11 It’s fine, in general you want to keep all your weight centered as much as possible.
Threads: 117
Likes Received: 810 in 658 posts
Likes Given: 126
20 Some frames even come with fc mounting holes infront or behind the esc...
Threads: 172
Likes Given: 4,721
100 30-May-2021, 05:59 PM (This post was last modified: 30-May-2021, 05:59 PM by hugnosed_bat.) the placement doesnt affect to the gyros work, it can be placed everywhere.
sure you can mount it 3mm away.
another solution could be a micro usb adapter, if you like to use original stack holes.
