07-Jul-2017, 11:05 PM
quick question, if the Taranis qx7 support 2S and 3S lipo.
And is it the same performance when I use a 2S 1800mah and 3S 1800mah?
Can I use 3S LiPo on QX7? |
07-Jul-2017, 11:05 PM quick question, if the Taranis qx7 support 2S and 3S lipo. And is it the same performance when I use a 2S 1800mah and 3S 1800mah? 07-Jul-2017, 11:06 PM The 3S one will run longer because it stores more energy... multiply voltage with capacity you get the energy it stores Q7X Operating Voltage Range: 6~15V DC (2S, 3S Lipos are acceptable), JST-XH 2S balance plug (center pin is not used). I use LiFePO4 2000mah 2S battery. It lasts for days! |
Crossfire diversity nano on backup lipo does not switch off | fpvapnea | 11 | 309 | 07-Mar-2024, 03:39 PM Last Post: StuweFPV | |
Help RSSI callout Taranis QX7/OpenTX? | swequad | 1 | 267 | 13-Jul-2023, 03:05 PM Last Post: SnowLeopardFPV | |
No tools/menu available (Taranis QX7) | Felynx | 6 | 3,857 | 19-May-2023, 06:41 AM Last Post: BadRaven | |
Help R-XSR+Taranis qx7 telemetry does not work | demvlad | 9 | 1,121 | 02-Mar-2023, 10:57 AM Last Post: demvlad | |
Can't bind QX7 to new Meteor75 | JinxFPV | 6 | 550 | 16-Dec-2022, 12:19 AM Last Post: JinxFPV |
