Hi .
Have something wierd with a few diversity nano receivers on my LR quads/planes. I decided to add a small 1s (managed) backup battery to all of them so i can use find/beacon mode. One works fine but with 2 out of the 3 the RX stays powered on when removing lipo or usb power untill backup bat drained. For the life of me i can not figure out why as all 3 same fw, settings etc. Any bright ideas on why this happens ?
Tried to troubleshoot by disconnecting everything from it (one by one to see if any of the connections to the FC could cause this, but even with everything disconnected , it just stays on. Can manualy switch it between normal and find mode , stays conected fine but does not shut down. On the one that is working correctly it just shuts down immediately when i unplug for example usb after playing with it on the bench. Also when testing with arming etc on the working i get on my TX a message to either shut it down as running on bat power or switch to find mode.
Feels almost like it does not think it is running on bat power while it is for the other 2.
Cant see any difference between the working and non working. Am out of ideas atm
