Boxer Max with cnc buttons,knobs and gimbals
Looks like RadioMaster is offering their Boxer as a Boxer Max.
 Price is attractive for what it comes with.Cnc gimbal set added to Boxer would cost more.
  [Image: a2YZSuhl.jpg]
    Features
  • Optional 3 colors - Black/Red/Gold
  • AG01 hall gimbals installed
  • Carbon fiber pattern case
  • CNC buttons and roller as standard
  • Adjustable length CNC metal folding stand
  • Upgraded black leather grips
  • Available with built-in ExpressLRS RF modules
  • Featuring a powerful STM32F407VGT6 with 1MB Flash and 192KB RAM
  • Preinstalled EdgeTX firmware
  • Internal ELRS module capable of 1,000Hz refresh rate
  • Adjustable ELRS RF output
  • QC3.0 fast charging support 2.0A MAX
  • Compact design with excellent ergonomics
  • New low-profile latching SE switch and momentary SF switch
  • Oversized battery compartment- Space for a 2S 6200mAh pack, up to 20-hour duration (Batteries not included)
  • Standard JR module compartment
  • Internal module cooling fan built in (ELRS version)
  • RadioMaster standardized button layout
  • Versatile 6-position switch for flight mode access
  • Adjustable and Removable T-shape Antenna
  • Industry first fabric handle for improved portability
  • Changeable, ergonomic grips
  • Redesigned SD card slot with new and improved 512mb pre-loaded SD card included
  • External module power slots in battery cover
  • RadioMaster signature carry case and gimbal protector are included as standard to ensure your radio stays safe while on the move
Specifications
  • Item: BOXER Max Radio
  • Color: Black/Red/Gold
  • Size: 235*178*77mm
  • Weight: 532.5g
  • Frequency: 2.400GHz-2.480GHz
  • Internal RF: ELRS 2.4GHz
  • Supported protocols: Module dependent
  • Cooling fan: Built in (ELRS version)
  • Voltage Range: 6.6-8.4V DC
  • Radio Firmware: EdgeTX (Transmitter) / ELRS (RF module)
  • Channels: Max 16 channels (Receiver dependent)
  • Battery: 7.4V 2-cell Lithium-Polymer / Two 3.7V 18650 Lithium-Ion cells (batteries not included)
  • Display: 128*64 Monochrome LCD display
  • Gimbal: AG01 CNC Hall Gimbal
  • External module: JR / FrSKY / Crossfire compatible
  • Upgrade Method: USB / SD card & EdgeTX Companion PC software
  • BONUS: Radiomaster neck strap and CNC adjustable stand
What did I say Big Grin
It was inevitable that RadioMaster would release a MAX version of this popular transmitter which is exactly why I was telling people to hold off buying the standard version of the Boxer unless they were desperate. I'll wait for a few reviews but I'm hoping this one has a less cheap plasticky feel to it than the original.
  • droneduchess6677
For anyone with a bog standard RadioMaster Boxer who wants to upgrade it to be the same as the new MAX edition version, all the MAX edition parts are now available as accessories. See the post link below for more details...
https://intofpv.com/t-radiomaster-boxer-...-available
  Radiomaster Boxer Throttle Tension Issue jimskeet2002 5 3,244 14-Jan-2024, 09:27 PM
Last Post: Rob3ddd
  New Product RadioMaster Boxer Transmitter SnowLeopardFPV 29 5,220 30-Dec-2023, 06:42 PM
Last Post: husafreak
  New Product RadioMaster Boxer - MAX Upgrade Accessories Now Available SnowLeopardFPV 3 651 28-Dec-2023, 04:28 AM
  ELRS Boxer Beta SPI Rx no bind husafreak 6 601 27-Oct-2023, 05:16 PM
  Boxer switches issue - Solved - Thank you Hélix in Wonderland 5 1,412 04-Oct-2023, 01:32 AM
Last Post: Hélix in Wonderland
