Threads: 26
Likes Received: 2 in 2 posts
Likes Given: 7
0 I wired up an Avatar 1s lite to TX/RX2 on a HM X12 v2.1 board. I set the VTX in BF to 0 power and enabled pit mode hoping to minimize interference from the analog . I also cut a small UFL wire to leave plugged into the board. When running on 2s I get video but even a slightly rough landing causes the board to reboot. I pulled it all apart and rebuilt it with extra vibration damping between the boards and double checked to make sure nothing was loose. All good.
Can this be done properly, or at all? I think disabling the VTX altogether would be best, but I'm not sure if that is possible.
Thanks
Threads: 581
Likes Received: 8,917 in 6,597 posts
Likes Given: 1,425
786 Unfortunately I can find ZERO information on the current rating for the onboard BEC of the Happymodel X12 AIO FC. You can use any 5V pad but be aware that even the 1S Walksnail Avatar VTX draws a lot of current so just be careful what power output you set it to. If you try to use 350mW there is a good chance that you will run into brownout issues with the VTX where it can't get enough current from the FC and will just shut down as a result which is something you really don't want happening mid-flight. Make sure you do plenty of testing at close proximity where you will be able to retrieve your quad before you put your full trust in it.
Threads: 29
Likes Received: 405 in 305 posts
Likes Given: 321
18 If it's anything like the Crazybee 2.1's regulator, it might not even be a full 1 amp.
