Aux 12 going crazy
Helloo, I'm sure my problem has been answered before, I rmemeber reading about it but I can't remember what to do. I bound up a beta85 to an x9d+. The receiver is an xm+. On reciever tab channel 12 is going nuts. I'm pretty sure it has something to do with rssi? The rssi channel on the dropdown menu is on disabled. I had this issue before I think too. Just cant remember what I did.
So it is likely the RSSI. if you enable aux 12 (aka ch 16) for RSSI, you will have that telemetry I can use the OSD.
(08-Apr-2021, 02:34 AM)voodoo614 Wrote: So it is likely the RSSI. if you enable aux 12 (aka ch 16) for RSSI, you will have that telemetry I can use the OSD.
Ok I did that. Got rssi in osd now. Channel 12 still flipping out though, is that normal or should it have calmed down?
Channel 12 represents the RSSI value. It will change as the RSSI changes. Given a fixed distance between the receiver and radio, it should be stable if you are not changing the distance.
  • Antek55
Question Motors going crazy at some point FeuerKai 2 247 05-Feb-2024, 09:21 PM
Last Post: FeuerKai
Question Setting AUX channels initial level TVT 6 703 31-Oct-2023, 03:37 PM
Last Post: wizofwires
Sad The motors don't work right and go crazy. Angelsinterceptor 3 239 22-Oct-2023, 10:41 AM
  After upgrading ELRS RX/TX to 3.2.1 the control went crazy. Angelsinterceptor 22 1,996 02-Jul-2023, 04:52 PM
Last Post: Carlosmoga
  Fractal65 Crazy Vibration on Takeoff- Then Fly-Away FPVme 8 338 24-Jun-2023, 12:49 AM
