Anyone know if i could update a hyperion vengeance cleanflight 1.10 to betaflight?
I've searched the net and no one has attepted it. I have this drone flying good on cleanflight naze 1.11.0 but i'd love to find a betaflight flash. I found the boot pins on the board. Just wondering if anyone has any insight. My other drone has a sp3 in it but the flash version only goes to 4.06. I really want to try presets with these old drones but doesnt look like thats at all possible.
The latest version of Betaflight that supported the NAZE FC was Betaflight 3.2.5 (see the link below). There are no presets on those old versions, so you are unfortunately out of luck with that.
https://github.com/betaflight/betaflight...tag/v3.2.5
i had one in my hands back than, i believe its realy a spektrum piece of fpvs early days.
personal the only thing i would use would be the motors.
i would buy a lightweight 5" or 6" frame, everything else and build a cruiser for flighttime with that motors.
If you guys don't mind telling me how do i save my original flash incase i want to go back to 1.10 cleanflight(hyperion says this is a custom board. I'm kinda scared to flash this since its flying so well. Only issues is it drops about 3 feet out the sky in rolls...so i'm trying to figure that out and can only use cleanflight 1.2.6 and a old version of chrome to get cleanflight working. I wish i knew someone in my area who could tune this thing to perfection(ive asked on local facebook groups but heard nothing back) I'm wondering if its possible to get this flying as well as if i upgraded to betaflight 3.2.5.
it sounds like you get motordesyncs.
you can increase idle speed in cleanflight or try to not release the throttle to much (never zero throttle) maybe it solves it.
if it has a blheli esc, you can increase motortiming, decrease starup power and set demag compensation to high for a lower chance of desync
it could be a sign for a bad motor, a bad esc or much noise in the system.
tighten and check the carbon tubes, frame about possible vibration sources
(01-Dec-2023, 08:57 PM)hugnosed_bat Wrote: it sounds like you get motordesyncs.
its got stock pids etc...show i increase roll rate in the osd first?
the rates ahouldbt cause the issue, i wouldnt aim them as source
does it roll out of the sky allways on the same motor or various?
(01-Dec-2023, 10:21 PM)hugnosed_bat Wrote: the rates ahouldbt cause the issue, i wouldnt aim them as source
it flew fine so maybe it was pilot mistake since that was my first roll ever. i jacked it up really high and rolled...i just figured it would roll on a dime but seemed to lag and lose some altitude. It couldve been me on not on the throttle all the way but i just feel it doesnt roll fast enough compared to some videos i've watched of other quads online. I only tried rolling it to the right with its tail towards me.
I switched over to betaflight 3.25 and motors 3 and 4 didnt work. Here is a link to others helping me out which includes a dump and resource. My vengeance originally come with a gimbal camera which in resources it shows 6 motors. one and two are the gymbals. Another guy had the same problem and did this https://forum.flitetest.com/index.php?th...ing.55619/ he used resource and put the two non working motors on 5 and 6. He wasnt sure if it was the best idea. Could i just put the motors on 1 and 2 through cli or should i use 5 and 6? here is the dump
.txt   new dump 3and4 motors wont wrk.txt (Size: 10.7 KB / Downloads: 16)
You can move motor 1&2 to motor 5 and motor 6.
resource MOTOR 1 B08
resource MOTOR 2 B09
resource MOTOR 5 none
resource MOTOR 6 none
Save
You will need to solder motor 1 signal wire to motor 5 pad. And motor 2 signal wire to motor 6 pad.
(06-Dec-2023, 01:11 AM)voodoo614 Wrote: You can move motor 1&2  to motor 5 and motor 6.
Save
 I was looking for the easiest solution since there has to be one ...right? I mean the drone works fine in cleanflight 1.1.0 but then has a motor issue in betaflight...just seems its got to do with programming and no soldering is nescesscary  Popcorn
It is likely resource conflict. Most like DMA or timer. When I get a chance, I can look into it. In the meantime, you can try a different firmware like 3.5.
(06-Dec-2023, 02:14 AM)voodoo614 Wrote: It is likely resource conflict. Most like DMA or timer. When I get a chance, I can look into it. In the meantime, you can try a different firmware like 3.5.
I havent read yet that its possible to use 3.5 on a naze32...i'll try it if it is. Thanks so much for your help!
I think version 3.25 is the last one.
#15
(06-Dec-2023, 02:32 AM)voodoo614 Wrote: I think version 3.25 is the last one.
it is...tried it and no two motors,,,found cleanflight 2.50 but i really want betaflight
  Should you update firmware? Rob Axel 30 824 14-May-2024, 02:00 PM
  CrossFire Connection Issues-Radio Master Zorro- No Betaflight input Apex FPV 3 164 06-May-2024, 02:35 PM
  BetaFlight Connection Issues..... Coleon 17 726 02-Apr-2024, 12:26 PM
Last Post: iFly4rotors
  Betaflight 4.4.3 on Speedybee F4V4 Ladu 4 259 14-Mar-2024, 04:45 PM
Last Post: Ladu
  Betaflight Configurator little yellow tick marks soky157 3 251 23-Jan-2024, 11:25 PM
Last Post: soky157
