A question about capacitors
My 4-in-1 ESC came with a capacitor pre soldered in, 35 volt 470uF, the problem is that it will not fit in my frame the way it is mounted and the leads are so short I cannot reuse it. I have some spare panasonic 35volt 1000uF capacitors. Can I use those or do I need to get a 470uF capacitor???
(21-Jul-2023, 09:11 PM)donwie63 Wrote: My 4-in-1 ESC came with a capacitor pre soldered in, 35 volt 470uF, the problem is that it will not fit in my frame the way it is mounted and the leads are so short I cannot reuse it. I have some spare panasonic 35volt 1000uF capacitors. Can I use those or do I need to get a 470uF capacitor???
My problem is that the way the capacitor sits it is sandwhiched between the DJI 03 Air Unit and the top carbon fiber plate. I could just take my dremel and grind a little carbon fiber away but I don't know if that will weaken the top plate???
With caps you can go up in voltage and capacity but like a drone frame or a circuit board space can be at a premium. You've already got it and think it will fit so use it especially if it is a genuine Panasonic.
Regarding lead length, personally I would not try to have the metal leads of a cap be too long as they are very brittle and wouldn't trust them to excessive crashing. In that case I'd cut the solid wire legs mostly off and solder silicone wiring to them. Of course you want to keep that cap as close to the ESC as possible.
A little trick I use for capacitors that need more space is to solder some leftover motor wire onto the leads to extend it, then I zip tie it to an arm. Despite not looking protected, it's actually pretty safe on there.
[Image: S0h8f8gl.jpg]
There is a video on Youtube somewhere with a guy testing caps on single esc's, on bat leads, on battery pads, etc and he said doing it the way Suros does was a better way than just having it on the pads. Also easier to place it somewhere convenient.
Try Not, Do or Do Not
- Yoda
  FC Question HarleySir 8 181 16-Apr-2024, 09:24 PM
  Soldering question Hummus 8 340 05-Mar-2024, 02:09 AM
Wink Stupid question: Eyes.fpv 4 219 03-Mar-2024, 05:44 PM
Last Post: husafreak
Exclamation Noob Question..... "VTX/ESC" Boards.... Coleon 12 437 02-Mar-2024, 12:35 PM
Last Post: Luk5569
  DJI Headset Stupid Question.. Coleon 1 154 01-Mar-2024, 10:53 AM
