Threads: 53
Likes Received: 52 in 27 posts
1 so iv'e been having this NO VFAS situation when discovering sensors.... and trying to set up audible voltage warnings !!!! i did enough playing around and video watching to kill a horse.. lol. i figured it out . the S.PORT was not connected from the receiver to the FC.... SO i got all of them working.... except one of the two powercubes.. One of them im using a X8R receiver and all the sensors are now showing up.... but on the X4R-SD i have in connected the same way S.PORT to the Tx pin on the UART all the sensors are coming up BUT the VFAS !!!!! any thoughts.....
Threads: 125
Likes Given: 99
388 Can you post photos of your wiring and a dump file.
Threads: 125
Likes Given: 99
388 Got your PM regarding the PowerCube. Glad you got that working.
As for Flycolor, the wiring looks correct. But you DO NOT have S. Port telemetry turn on in the Port tab. I believe S. Port is hook up to UART 2. Once you have it turn on, try different combinations of on and off for both tlm_inverted and tlm_halfduplex. If UART2 does work, turn S. Port telemetry on in UART1. The manual does not state what UART is the S. Port pad.
Threads: 125
Likes Given: 99
388 Under Port tab in BFC. Look for Telemetry and there is a pull down for Smartport.
Threads: 125
Likes Given: 99
388 Telemetry should work. It should be UART1 or UART2. UART3 is for you stick controls. Do you change tlm_halfduplex also?
Threads: 125
Likes Given: 99
388 Very nice. All about the small victories.
