31-Oct-2022, 11:04 AM (This post was last modified: 31-Oct-2022, 01:42 PM by C_Sagan_42.)
I have an old Eachine wizard x220s that I bought in 2016 or something, have just borrowed a X8R from a friend to try and get it up and running.
In betaflight I have no stick inputs and have rx_failsafe as an arming issue. My Taranis QX7 and the X8R are bound.
- Flashed latest betaflight to Omnibus F4 V3 Flight Contoller
- Not sure what firmware the X8R has on it, but I managed to bind my QX7 when I flashed firmware_x7_lbt_en_200617 and XJT_EU170317.
- I have the Gnd, 5V and SBUS wires from the X8R going into the Gnd, 5V and dedicated PPM/SBUS ports on the FC. And the SBUS/PPM switch is soldered for SBUS.
- Green LED on X8R
- But no stick inputs in betaflight and arming flag rx_failsafe is always there.
Can anyone please help me, I've tried all the UARTS, I've tried using the Smart Port, I've checked the soldering. I've tried set serialrx_inverted ON/OFF and set serialrx_halfduplex ON/OFF.
I have no idea what to do
dump and a couple of photos attached
Thanks you
- Green LED on X8R
Thanks you
![Smile Smile](https://intofpv.com/images/smilies/smile.png)
