Which battery mod to EV800D?
Hello! I wanna change this tiny battery in Eachine ev800d to something normal. Could you tell me which option will keep goggles longer enable?
1. Basket with Li-Ion batteries 18650 3400mAh on head strap
2. Make XT60 input, and connect it with long cable to lipo 2s 3000mAh in pocket
I know that many of you make such modifications, can you boast about the battery time of the goggles?
I am leaning towards the first option, but I heard that the ev800d have a worse range as the voltage drops below 7.5-7.6V. From what I can see, the Li-Ion operates at a slightly lower voltage than stock lipo in this goggles, so I am afraid that I will not lose range and efficiency.
Sad Help EV800D vs EV800DM LeoMarques 5 1,400 01-May-2024, 03:13 PM
Last Post: wepp
  EV800D Manual and Power Lead Question Pathfinder075 13 1,149 17-Dec-2023, 04:25 PM
Exclamation Help EV800D one source not working Zaartan 3 1,873 14-Dec-2023, 12:52 PM
Last Post: Mash
  Help VTX works when connected to PC, but not on battery power thetruemystic 14 925 29-Aug-2023, 01:17 AM
Last Post: luispequeno
  battery recommendation for 04X stxrus 6 618 16-Jul-2023, 01:26 PM
Last Post: Pennywise
