09-Oct-2020, 10:26 AM
Hi guys, I have some questions about antenna and what is difference between RPSMA Male and SMA Male Antenna?
What is the difference between RPSMA male and SMA male antenna? |
09-Oct-2020, 10:26 AM Hi guys, I have some questions about antenna and what is difference between RPSMA Male and SMA Male Antenna? 09-Oct-2020, 10:29 AM Male and female pretty much. I think sma is usually used with RHCP My Facebook Page | My Youtube Channel iFlight Green Hornet 1 | Emax Tinyhawk Freestyle 2 | Emax Tinyhawk 2 ISDT 608 & Balance Board | Eachine EV800D | Taranis Qx7 | TBS Crossfire Mini v2 09-Oct-2020, 10:36 AM 09-Oct-2020, 10:55 AM (This post was last modified: 09-Oct-2020, 10:55 AM by SnowLeopardFPV.) See the following article bu Oscar which explains it all with photos... https://oscarliang.com/difference-sma-rp...fpv-copter 09-Oct-2020, 10:57 AM Male and female stuff, you know, pointy thing, hole... A bit awkward if we think about it. You always have to match the hole with the pointy thing to have connection,but you have also to check the one that screws and the one that gets screwed... Hummm... I'm not trolling, this can be hard to explain... Check some images on google, you will get it. Just be careful with the keywords you use. Hi, the article in Oscar's page is great, this also helped me: -External threads = female -Internal threads = male With that in mind, in a female you expect a hole and in male you expect pin. If it matches then SMA. If it is the opposite then RP-SMA Santi 09-Oct-2020, 05:21 PM VTX is always female. The antenna is always male. The big difference between the SMA and RP-SMA, is the center pin. SMA is the standard coaxial connection you see on older TV for over the air antenna. Or pretty much any audio/video coaxial connection. Originally, from what I reading, RP-SMA was invented as a security connector for the cable company. It was not easy to find RP-SMA connector back in the days. |
vtx antenna cable and ground shorting | paulius | 15 | 1,698 | 26-Jun-2024, 08:22 AM Last Post: iFly4rotors | |
MOXON antenna | hawk01 | 6 | 427 | 31-May-2024, 07:01 PM Last Post: SeismicCWave | |
Dual antenna of OG Air Unit combined into one | Fpv_Snidde | 2 | 146 | 21-Apr-2024, 09:19 AM Last Post: Fpv_Snidde | |
Use a different antenna | Eyes.fpv | 3 | 305 | 28-Mar-2024, 05:13 PM Last Post: Pathfinder075 | |
First Build - prevent antenna chop? | JohnnyCornRocket | 5 | 305 | 28-Mar-2024, 02:16 PM Last Post: iFly4rotors |
