Threads: 83
Likes Received: 8 in 8 posts
Likes Given: 229
0 Hey
If I use the Crossfire antenna U.FL on the elrs receiver, will the range differ?
I used one, and the range was good, and I used another, but the range was bad
Threads: 581
Likes Received: 8,917 in 6,597 posts
Likes Given: 1,425
786 28-Mar-2024, 11:37 AM (This post was last modified: 28-Mar-2024, 12:09 PM by SnowLeopardFPV. Edit Reason: Typo corrections. ) Are you using the 2.4GHz ELRS receivers, or the 900MHz ELRS receivers? Most people are using the 2.4GHz ExpressLRS setup so I will assume you have the same.
You can't use a TBS Crossfire antenna on a 2.4GHz receiver because the Crossfire antennas are tuned for a 900MHz frequency. If you managed to get a Crossfire antenna to work on a 2.4GHz ELRS receiver then I'm surprised and it is just luck that you managed to get any kind of range at all, but I wouldn't risk using the quad again with that antenna on it. Put an antenna on that is tuned to the 2.4GHz frequency.
Threads: 74
Likes Received: 1,336 in 996 posts
Likes Given: 771
41 28-Mar-2024, 05:13 PM (This post was last modified: 28-Mar-2024, 05:13 PM by Pathfinder075.) BetaFPV generally sell packs of two dipole antennas for ELRS for very little money. If you need to pad an order out, throw a couple of packs of them into your cart. They are really useful. I try to keep a few of them in my spares box as i've destroyed a couple of them in bandos.
Try Not, Do or Do Not
- Yoda
