26-Mar-2024, 09:54 AM
can i print a 5mm thick cup to put my ospray ariel inside as i keep cracking the outer cover on them in my local bando.. will doing this cut down on connection to the vista neb pro ?
justofpv
ospray antenna |
26-Mar-2024, 09:54 AM can i print a 5mm thick cup to put my ospray ariel inside as i keep cracking the outer cover on them in my local bando.. will doing this cut down on connection to the vista neb pro ? justofpv 26-Mar-2024, 10:10 AM Dont miss to try a durable inexpensive dipole for your bando, sometimes they deliver a better image quality than omnidirectional ones and are more durable and inexpensive to replace either. A tpu support like this can increase durability alot: 26-Mar-2024, 10:53 AM thankyou is the stl for your antenna available to download and print justofpv 26-Mar-2024, 08:50 PM I just puicked a random photo from picture search, i use some either. What frame do you have? If its popular, there might be some designs made for it, maybe for your ospray. If not, you could correct a design to fit your frame or someone gently might design for you if you ask for it inhere :-) |
Dual antenna of OG Air Unit combined into one | Fpv_Snidde | 2 | 81 | 21-Apr-2024, 09:19 AM Last Post: Fpv_Snidde | |
Use a different antenna | Eyes.fpv | 3 | 165 | 28-Mar-2024, 05:13 PM Last Post: Pathfinder075 | |
First Build - prevent antenna chop? | JohnnyCornRocket | 5 | 208 | 28-Mar-2024, 02:16 PM Last Post: iFly4rotors | |
What is the best antenna for goggles with ONE receiver (Ls800d)? | samysh | 16 | 538 | 14-Mar-2024, 07:11 PM Last Post: brettbrandon | |
Measuring / Extending the TBS Immortal T Antenna.... | Coleon | 5 | 327 | 11-Feb-2024, 02:10 AM Last Post: iFly4rotors |
