05-Oct-2022, 06:30 AM
Wanted to share my first Walksnail build with you guys. This build was completed last week and I have been having a lot of fun with it. I chose a small frame for my first build so I could fly it around the house. Outside of course.
Forgive me there is a bit to share in this thread, I'll try to keep it brief!
Parts list
Keep in mind:
Battery goes to FC, from FC there is the filtering capacitor. Connected to the filtering cap is the MATEKSYS BEC (configured for 9V) which is then passed into the loom/JST connector for the walksnail vtx. To me this ensures that the vtx is getting some well filtered power. This is a 4S quad. Powered by 4S 450mAh BONKA lipos.
Ideally I wanted to use some RCINPOWER 1207 motors I had, but one of them died which is a pity. I took a chance and used the 1204 motors I had in the parts box - was worried they just wouldn't have the power but in the end they seem fine. Needed a bit of tuning though to stay smooth and definitely RPM filter made a difference once I turned that on.
I attached the TrueRC antennas to the VTX and then played around with the orientation, noting the design points I outlined above. I used a lighter to heat and shape the vtx antennas to match the outline of the quad and to be mounted on the arms.
Bringing the VTX and FX together for the flight stack. Now you can see the wiring layout for the power/uart JST connector and the U.FL connectors on the antennas. Also, trying to keep the vtx antennas at a 90degree angle to each other. This way when you're in the dead zone of one antenna the other antenna is fine.
Here you can see the vtx clearance for cooling and the strain relief on the vtx antennas. That 4 pin JST sitting in the vtx heatsink is the USB connector. I fly with this plug covered as it attracts crap, cut grass, etc...
I am happy with the layout for now. So I installed the cable ties to secure everything. Also the vtx antennas are reinforced with some cable ties to keep them rigid. Here are a couple of pics before the top plate goes on.
Out for some flights, testing, etc...
Tuning log:
Here is a rip around my house which is undergoing some major renos = sh1te everywhere....
This is DVR from the googles, the system is running 1080P at 60fps, it is freakin amazing.
This is some comparison footage between the onboard DVR and goggle DVR.
Watch them in 4K if you can.
I'm only flying in 1080P mode atm, for me this is walksnail's greatest unique selling point, otherwise I would just stick with DJI.
![Tongue Tongue](https://intofpv.com/images/smilies/tongue.png)
Parts list
- Armattan Tadpole 3" - HD version
- RCINPOWER - 1204 5000kV motors
- MAMBA F722 MK1 AIO FC
- Walksnail VTX with nano camera
- TrueRC singularity LHCP VTX antennas (x2)
- MATEKSYS 9V BEC
- HM EP2 ELRS RX
- EMAX AVAN Mini 3" props
- VTX orientation - The JST connectors on the airunit can be easily damaged, having the power/uart JST connector facing the rear of the quad reduces this risk
- U.FL connectors on VTX - there are two of these and the antennas need to be secured well with strain relief - Those TrueRC antennas aren't cheap!
- BEC powering VTX - Just to be safe I'm using a MATEKSYS 9V BEC to power the VTX - All I have had is success with these on my digital builds so far
- Small!
- Has two mounting options for a front and rear stack. The front is AIO 25.5mm and the rear is a mix of 12x16/20x20. Unlike the non-HD tadpole, this one has the 25.5mm stack in the chassis, the original tadpole has to use an adaptor to mount a 25.5mm AIO.
- Nice big camera cage - in the end I should of used the micro sized WS camera and not the nano one - you will see in the videos the camera cage because of the nano camera sitting quite (safely!) far back.
Keep in mind:
- VTX has two JST connectors and you need to be able to get to both, all the time. One is for power/uart and is obviously critical but the other is to access USB on the vtx for firmware updates AND access to the onboard DVR - yes all WS vtx have an onboard DVR, sweet!
![Thumbs Up Thumbs Up](https://intofpv.com/images/smilies/custom/thumbs-up.png)
Tuning log:
- Originally running without RPM filtering, wasn't handling the best on throttle punchs and propwash was easy to trigger. Even with less P and D not the best.
- Installed bluejay 0.16 with rpm filtering made it a lot better.
- D at 0.8 on simple sliders
- TPA at 1200 given the power/weight is solid with this quad.
- Filters at 1.2 I think
![Cool Cool](https://intofpv.com/images/smilies/cool.png)
![Big Grin Big Grin](https://intofpv.com/images/smilies/biggrin.png)
