Posts: 37 Threads: 5 Likes Received: 4 in 4 posts Likes Given: 38 Joined: Jun 2019 Reputation: 0 25-Aug-2019, 06:40 AM (This post was last modified: 25-Aug-2019, 06:42 AM by m0nk444.) Hey all, I'm still new. I've been struggling to get good fpv feed. It worked decent the first few sessions and then starting dropping completely. Same location (open field). Vtx is on the same channel as goggles (A/5 5785, 200mw) RH antennas, FS attitude v5, eachine TX5258. I am running a capacitor pigtail rig. I did have to replace the stock capacitor Sanyo 1000uf 25v with another Sanyo 1000uf 30v from radio shack because I prop thrashed it.... Just for reference my cam is the foxeer arrow mini pro 2.5 Is there a certain channel/preferred/bad/good? It completely drops on me lately whenever I get 60ft ish. Vtx/antenna is not touching carbon fiber or close to Fc. Ideas? Wisdom? Sorry no pics, can't figure out how to bring pics and I couldn't select a prefix. • Posts: 12,098 Threads: 125 Likes Received: 3,739 in 2,836 posts Likes Given: 99 Joined: Feb 2017 Reputation: 388 https://intofpv.com/t-how-to-upload-pictures Did you swap out attitude antennas or kept the OEM? It is worth a try to change out for better antennas. • Posts: 37 Threads: 5 Likes Received: 4 in 4 posts Likes Given: 38 Joined: Jun 2019 Reputation: 0 (25-Aug-2019, 07:26 AM)voodoo614 Wrote: https://intofpv.com/t-how-to-upload-pictures Did you swap out attitude antennas or kept the OEM? It is worth a try to change out for better antennas. I have both oem on the goggles. I put a pagoda omni on the vtx. I will change the goggle antennas asap. I should have done that already... Thank you and thanks for the link ? • Posts: 12,098 Threads: 125 Likes Received: 3,739 in 2,836 posts Likes Given: 99 Joined: Feb 2017 Reputation: 388 60 ft is quite short, even on OEM antenna. There might be something wrong with your setup. Do you have more than one quad? Is it happening on more than one quad or just one? I am trying to rule out the goggles. • Posts: 37 Threads: 5 Likes Received: 4 in 4 posts Likes Given: 38 Joined: Jun 2019 Reputation: 0 25-Aug-2019, 10:49 AM (This post was last modified: 25-Aug-2019, 10:50 AM by m0nk444.) (25-Aug-2019, 09:23 AM)voodoo614 Wrote: 60 ft is quite short, even on OEM antenna. There might be something wrong with your setup. Do you have more than one quad? Is it happening on more than one quad or just one? I am trying to rule out the goggles. Only one quad. Here's the story, I got my goggles, turned everything on, did a channel search in my house, got a good pic, went and flew at the normal open field.... About a week went by, flew 6 packs a day, things were fine. Then one day (same location) video feed started doing the drop off thing. I did a little research and realized I didn't have my goggles and vtx on the same channel. Same band, just a couple channels off. So I corrected that and headed out expecting outstanding results ? I still had video dropping at that short distance. That's when I realized I've exhausted my knowledge and corrections I could do personally at the moment. So here I am lol. Maybe it's more like 100 feet... But def not farther than that. I'm judging this distance off of my dirt bike jumping days, so I think I'm close on distance. Fortunately this hobby has taught me patience I used to NOT have. • Posts: 12,098 Threads: 125 Likes Received: 3,739 in 2,836 posts Likes Given: 99 Joined: Feb 2017 Reputation: 388 I would double check that band/channel are the same. I would check the antenna is on tight both the SMA and the pigtail to the VTX if you have one. Posts: 2,410 Threads: 136 Likes Received: 1,790 in 1,052 posts Likes Given: 3,302 Joined: Jan 2017 Reputation: 50 As Voodoo mentioned I would search for a loose connection somewhere. I have had solders break/crack where the SMA is soldered to the board. Posts: 37 Threads: 5 Likes Received: 4 in 4 posts Likes Given: 38 Joined: Jun 2019 Reputation: 0 26-Aug-2019, 02:13 AM (This post was last modified: 26-Aug-2019, 02:15 AM by m0nk444.) I have a bunch of parts for a 2nd build. I'm going to start over and see what happens. Thanks a TON for all you guys help/ideas/responses. So very much appreciate your time. Posts: 37 Threads: 5 Likes Received: 4 in 4 posts Likes Given: 38 Joined: Jun 2019 Reputation: 0 27-Aug-2019, 12:42 AM (This post was last modified: 27-Aug-2019, 12:43 AM by m0nk444.) My positive wire was connected to a 5v pad..... I removed and hooked it to vbat.... I'm expecting great results. Will try this evening. Thanks again voodoo and droneOfprey!! I'm still going to assemble my other parts • Posts: 12,098 Threads: 125 Likes Received: 3,739 in 2,836 posts Likes Given: 99 Joined: Feb 2017 Reputation: 388 27-Aug-2019, 01:39 AM (This post was last modified: 27-Aug-2019, 01:39 AM by voodoo614.) (27-Aug-2019, 12:42 AM)m0nk444 Wrote: My positive wire was connected to a 5v pad..... I removed and hooked it to vbat.... I'm expecting great results. Will try this evening. Thanks again voodoo and droneOfprey!! I'm still going to assemble my other parts This is probably your problem. Your VTX is 7-24V. I am surprised that it even works on 5V. I am glad you didn't burn your 5V regulator . Posts: 37 Threads: 5 Likes Received: 4 in 4 posts Likes Given: 38 Joined: Jun 2019 Reputation: 0 (27-Aug-2019, 01:39 AM)voodoo614 Wrote: This is probably your problem. Your VTX is 7-24V. I am surprised that it even works on 5V. I am glad you didn't burn your 5V regulator . LOL!! Well... I fired it up in the house for a quick inspection, didn't get what I was looking for. Smelled some electrical burn... Vtx has power. I'll have to dig into it later when I'm more free. Like a lot of peeps, part of me enjoys tinkering around with this to a point. The good thing is, I can always LOS. I've got myself in the position that... I can always get my daily fix @))) I love this hobby and there is great support from you veteran guys. Again, that is much appreciated. I haven't drove my arrma typhon at all this summer lol. These qwads have 100% of my attention. I'm going to build all winter. My dad picking up a phantom series is what got me to this niche. Anyway, thanks for the the helps. I'll keep you guys updated • Posts: 6,117 Threads: 172 Likes Received: 2,288 in 1,835 posts Likes Given: 4,737 Joined: Feb 2019 Reputation: 101 my aarma raider need a new servo and it have to wait aswell, as long as i stay in the air with something x-D my 2lipos arrma lipos are used serial, for use as openfield-charger-lipos :-) i guess the typhon drive regulary on 4s? there is a good use for them while the arrma stay at home ;-) Posts: 37 Threads: 5 Likes Received: 4 in 4 posts Likes Given: 38 Joined: Jun 2019 Reputation: 0 (27-Aug-2019, 02:58 AM)hugnosed_bat Wrote: my aarma raider need a new servo and it have to wait aswell, as long as i stay in the air with something x-D my 2lipos arrma lipos are used serial, for use as openfield-charger-lipos :-) i guess the typhon drive regulary on 4s? there is a good use for them while the arrma stay at home ;-) I ride/rode the 3s model. I can NEVER get any of my cars alignment good lol lol. I enjoy flying so much more these days in my life • Posts: 37 Threads: 5 Likes Received: 4 in 4 posts Likes Given: 38 Joined: Jun 2019 Reputation: 0 I fried the tx5258 when I powered it from vbat? Strange. That's where it should have been powered from in the first place. Anybody have a recommend on a new vtx? I don't mind spending a little more on a solid one. • Posts: 12,098 Threads: 125 Likes Received: 3,739 in 2,836 posts Likes Given: 99 Joined: Feb 2017 Reputation: 388 27-Aug-2019, 07:43 AM (This post was last modified: 27-Aug-2019, 07:44 AM by voodoo614.) Lots of solid VTXs. Do you want stack mount or non-stack? Some good brands. Matek, RDQ Mach, TBS, RUSH (from reviews), Tramp. That is really weird it fried. Something was probably going south already. |
