Threads: 3
Likes Received: 0 in 0 posts
Likes Given: 0
0 So I wrecked my flywoo explorer and now the video only works when I’m 3 feet from the drone and pointed straight at it ....I replaced the antenna (bc I had one handy) still only works three feet from quad ....I checked all wires everything seems fine ...wasn’t a hard crash but ended upside down ...any help would be appreciated
Threads: 122
Likes Received: 854 in 696 posts
Likes Given: 134
20 “So I wrecked my fly woo explorer...”. These components don’t say “Tonka” on them.. some crashes that will make u cringe only breaks props, others “not hard” or “didn’t seem bad”.. end up having some electronic component as collateral damage... I’ve seen FCs let out “magic smoke” from a single blade of grass...
Threads: 38
Likes Given: 430
118 Can you check smart audio RX wire connection to the vtx and FC?
Perhaps the vtx is stuck in pitmode. Try and manually set the power using the button function and confirm that the led flashes are indicating the correct power level.
Threads: 122
Likes Given: 134
20 If that doesn’t work (button on vtx) try setting it in betaflight..
Threads: 3
Likes Given: 0
0 This is what it says in beta I changed vtx an went back in an still says this
Threads: 4
Likes Received: 18 in 18 posts
Likes Given: 10
3 looks like is time for a new Vtx, Akk and rush make some nice ones.
I only know that i know nothing
Threads: 122
Likes Given: 134
20 ..rush "yes"..AKK, not so much.... honestly Ive got better performance from a $14 Panda rc than a $30 AKK... Just my $.02
Threads: 172
Likes Received: 2,297 in 1,844 posts
Likes Given: 4,753
103 31-May-2021, 02:01 PM (This post was last modified: 31-May-2021, 02:03 PM by hugnosed_bat.) 1000watt is a bit too much :-) 1watt is still plenty power ;-)
as example 400mw is still alot a could work for miles.
it depends on your radio gear, if you dont have crossfire or another lr radio gear - 200mw might still outperfrom your radio link than.
Threads: 172
Likes Given: 4,753
103 a tbs unify makes sense in combination
