10-Oct-2021, 09:43 AM (This post was last modified: 10-Oct-2021, 08:35 PM by Foxer_125.)
Hello brother, today I test my drone with 2 antennas, 1 helical 7 turn design for me and other antenna truer x2 air, in osd the helical is thque e signal up and truerc the signal down, i os, tbs unify vtx 800 mw and battery 2500 mha, I only can fly 1.8 kilometers of distance is normal??
The other dude that i have is,that I never use the 2500 mha and the battery fast down to 3.0 v each battery, is normal it?
The other dude that i have is,that in the dji goggles i have installed adapter with rapid fire, in the,rapid fire i select long range but what i dont understand is why always,rapid fire whe receive signal of vtx the buzzer do bip bip bip bip never stop the buzzer of the rapid fire is normal? This,is,the,video please
What antenna do you have on your quad? You will need a long stalk antenna that can clear the carbon and lipo for long range.
What exact Vtx do you have? The Unify Pro32 vtx? You may need to unlock it. And I am hoping you have the correct SmartAudio tables setup to ensure you are at the correct power level.
The Rapidfire will beep when it looses sync lock and beeps when the sync is re-established. This is normal as I saw it happen in your video as well. An indication when it looses sync lock is when the top RSSI bars disappear in the goggles.
I do not know where you are selecting Long range in the RapidFire menu. I do not even see that option IIRC.
For your battery voltage, you may not have the correct Voltage meter source selected in the Configurator or you may need to calibrate the Voltage meter sensor.
10-Oct-2021, 08:18 PM (This post was last modified: 10-Oct-2021, 08:38 PM by Foxer_125.)
Helo bro, this is the mode of rapid fire for long range, im using battery lion 2500mha 4s, and the seller said me that is tbs unify and the antenna on the drone is i flight albatross 5.8ghz 150mm rhcp fpv
For the battery information, check your scaling in BetaFlight. Plug your pack into the charger and see where the pack reads. Then you have to calibrate the scaling to get the numbers to align. I had this happening on my Drift build where it calculated the cell voltage up at about 3.2vdc when they were at 4.25vdc. A little shifting, now it reads the same as my meter.
SoCal Kaity :D OMG, no one told me it would be this much fun! Addicted :)
(10-Oct-2021, 08:18 PM)Foxer_125 Wrote: Helo bro, this is the mode of rapid fire for long range, im using battery lion 2500mha 4s, and the seller said me that is tbs unify and the antenna on the drone is i flight albatross 5.8ghz 150mm rhcp fpv
That Long range setting is an OSD display setup and not an RF mode. This only affects your OSD display.
Long range OSD mode shows the traditional RSSI bars, but also presents audible feedback for head misalignment and help keep the head aimed at the craft.
(10-Oct-2021, 11:50 PM)kafie1980 Wrote: That Long range setting is an OSD display setup and not an RF mode. This only affects your OSD display.
Aaa now i understand, what I dont know is why always present audible bip bip never stop the beep beep if the antenna are follow the drone the beep beep no stop
I think what you are seeing is typical analog video quality 2 km's out.
When you turn around the signal drops because the antenna gets blocked by the battery and the frame.
You also turned around because you started running low on battery voltage. So in other words your video setup is capable of outrunning the limits of your lipo range.
