08-Apr-2024, 03:45 PM
OK, Equipment in use today:-
GEPRC Mk 5 ELRS with DJI Air Unit (twin antenna)
DJI Goggles v2
Frsky Horus X12S with Namimno Flash 2.4GHz module
6S 1850mAh LiPo
A combination I have been using a LOT for over a year and has been excellent and fault free.
Event:-
On second flight of day at 300-350 metres range the quad at maybe at most a third of pack used and 3.8 av cell volt with video image good it did a slow uncommanded forward roll and fell to ground. As it was falling I noticed the goggles VIDEO signal strength at max four bars, but no CH(number) indicated. It stayed like that on the ground till I found it right way up in the lengthening dew damp field grass, reached it and carried it back. After check over (no damage, wet lens) I flew it carefully and the CH (number) was sometimes blanking for a second, while the four bars stayed at max. Battery voltage displayed was normal, at no time did the RADIO RSSI/Link Qual on ELRS stray from normal.
Landed, changed channel (from 3 to 6) and flew again, same as above intermittant loss of CH indicator, no other symptom. Flew battery out, landed checked voltage matched OSD indication.
Buddy flew (analog) , then I flew again on original CH3. It stayed on, no glitches or indication flicker.
8 more packs, increasingly aggressive, inc regular over spot of issue, all normal.
DJI Goggles v2
6S 1850mAh LiPo
Event:-
