(18-Dec-2020, 03:08 PM)Robert Rypuła Wrote: Nice!!! Over 5 minutes of flight time. Three questions:
1. What battery did you use? I have 450 mAh 1S batteries from Advanced Kit 2. I'm wondering if I could just join two of them (emulated 2S) and replace the battery plug to avoid buying another set of equipment and batteries.
2. Do you think (from your experience) in 75mm frame it will also fly well?
3. Did you get rid of Yello? Only this destroys overall experience
I have an assortment of 2s and 3s batteries and wasn't sure which I used. I just now tried two different batteries.
First, Hyperion G7 2S 600mAh batt got 5-1/2 minutes flight time (battery over 1 year old).
Second, Tattu 3S 450mAh batt got just short of 7-1/2 minutes of flight time (battery brand new).
This is with cinematic type flying, not ripping it.
On 2S it is a little sluggish but good for cinematic flying. It was snappier on 3S and flew better overall.
I don't think joining two 1S batteries will work very well as I don't think it will get enough power with the smaller pins and wire. Running 2S with a XT30 connector was a little sluggish and using the smaller connector and wire would make that worse.
To fly it in a 75mm frame I think I would drop the motor size to lose about 4 grams or so of weight. If the 65mm version I am working on (listed above) dosen't work, I will be transferring it to a 75mm frame using the same components and it will be simulated 2S to start with. If that dosen't work, I will try normal 2S with an XT30 connector....
Using new HQ props, the jello seems to be very minimal.
