Posts: 1 Threads: 1 Likes Received: 0 in 0 posts Likes Given: 0 Joined: Dec 2019 Reputation: 0 19-Dec-2019, 10:38 AM (This post was last modified: 19-Dec-2019, 10:38 AM by yamax87.) I'm flying a brand new TH S on tattu 2s 450mah batts. Gentle hovering around; nothing aggressive. Indoor flying (as a test run) in my lounge. Profile 2 pids (P value 80). Xt30 connector. After 4 minutes, the batt was drained and the motor bells were almost too hot to touch. 1s 450 and stock 2s 300 both fly fine. Bit confused...is this normal? I thought 2s 450 was what most people use, but I'm terrified of wrecking the motors. Is there anything else I can change? Thanks. • Posts: 12,098 Threads: 125 Likes Received: 3,739 in 2,836 posts Likes Given: 99 Joined: Feb 2017 Reputation: 388 The added weight could be causing the heat, especially if you are not getting the same heat from the smaller packs. Usually too much D term cause hot motors or not enough PID filtering. • Posts: 189 Threads: 19 Likes Received: 20 in 12 posts Likes Given: 26 Joined: May 2019 Reputation: 1 24-Dec-2019, 04:27 PM (This post was last modified: 24-Dec-2019, 04:46 PM by Corrado-c.) it happens to me the same, even with the 2s 300mah supplied I had stopped using 2s also because with the PID project mokingbird even with 1s is fantastic. later I installed BF 4.1 and RPM filters and the autonomy has increased up to 5 minutes. today I read your post I went to try the 2s again. cold engines and barely warm battery. • Posts: 9 Threads: 0 Likes Received: 1 in 1 posts Likes Given: 1 Joined: May 2020 Reputation: 0 Corrado-c I would be grateful if you tell me what kind of setup you use ine BF. I've installed Jesc 48, update BF to 4.1 but I'm struggling with BF setup.. can I use standard THS pid profiles, just change some details for jesc? • Posts: 189 Threads: 19 Likes Received: 20 in 12 posts Likes Given: 26 Joined: May 2019 Reputation: 1 (04-May-2020, 04:43 PM)Marcin636 Wrote: Corrado-c I would be grateful if you tell me what kind of setup you use ine BF. I've installed Jesc 48, update BF to 4.1 but I'm struggling with BF setup.. can I use standard THS pid profiles, just change some details for jesc? Hi!! Lately I was using esc JazzMaverick firmware for rpm filter! it works great, now I'm using BF4.2 and luckily I have some old saved settings. I am attaching the "diff all", which I had saved some time ago with BF4.1, see if you can catch something, most is the mockingbird project Code: # # diff all # version # Betaflight / STM32F411 (S411) 4.1.1 Nov 15 2019 / 12:55:17 (1e5e3d369) MSP API: 1.42 # manufacturer_id: MTKS board_name: MATEKF411RX custom defaults: YES # start the command batch batch start # reset configuration to default settings defaults nosave board_name MATEKF411RX manufacturer_id MTKS mcu_id 005d00623437510435313736 signature # resources resource RX_BIND 1 B02 # beacon beacon RX_SET # serial serial 0 64 115200 57600 0 115200 serial 1 2048 115200 57600 0 115200 # mode_color mode_color 5 0 9 mode_color 5 1 11 mode_color 5 2 2 mode_color 5 3 13 mode_color 5 4 10 mode_color 5 5 3 # aux aux 0 0 2 1775 2100 0 0 aux 1 1 0 1700 2100 0 0 aux 2 30 1 1800 2100 0 0 aux 3 35 3 900 1300 0 0 aux 4 47 0 1300 1700 0 0 # adjrange adjrange 0 0 0 900 2100 12 0 0 0 adjrange 1 0 3 1400 2100 29 3 0 0 # vtxtable vtxtable bands 5 vtxtable channels 8 vtxtable band 1 BOSCAM_A A FACTORY 5865 5845 5825 5805 5785 5765 5745 5725 vtxtable band 2 BOSCAM_B B FACTORY 5733 5752 5771 5790 5809 5828 5847 5866 vtxtable band 3 BOSCAM_E E FACTORY 5705 5685 5665 0 5885 5905 0 0 vtxtable band 4 FATSHARK F FACTORY 5740 5760 5780 5800 5820 5840 5860 5880 vtxtable band 5 RACEBAND R FACTORY 5658 5695 5732 5769 5806 5843 5880 5917 vtxtable powerlevels 1 vtxtable powervalues 14 vtxtable powerlabels 25 # master set gyro_sync_denom = 2 set gyro_lowpass2_hz = 500 set dyn_notch_range = AUTO set dyn_notch_width_percent = 0 set dyn_notch_q = 250 set dyn_notch_min_hz = 100 set dyn_lpf_gyro_min_hz = 400 set dyn_lpf_gyro_max_hz = 1000 set acc_calibration = -4,14,-20 set mag_hardware = NONE set baro_hardware = NONE set min_check = 1007 set max_check = 2000 set fpv_mix_degrees = 20 set airmode_start_throttle_percent = 55 set rx_spi_protocol = FRSKY_D set dshot_idle_value = 600 set dshot_burst = OFF set dshot_bidir = ON set motor_pwm_protocol = DSHOT600 set motor_poles = 12 set bat_capacity = 450 set vbat_max_cell_voltage = 450 set vbat_min_cell_voltage = 290 set vbat_warning_cell_voltage = 300 set current_meter = NONE set crashflip_motor_percent = 75 set small_angle = 180 set deadband = 3 set yaw_deadband = 2 set pid_process_denom = 1 set runaway_takeoff_prevention = OFF set osd_warn_no_gps_rescue = OFF set osd_warn_gps_rescue_disabled = OFF set osd_vbat_pos = 355 set osd_rssi_pos = 34 set osd_tim_2_pos = 14368 set osd_flymode_pos = 6201 set osd_anti_gravity_pos = 6381 set osd_vtx_channel_pos = 355 set osd_craft_name_pos = 362 set osd_avg_cell_voltage_pos = 14392 set osd_disarmed_pos = 14634 set osd_esc_tmp_pos = 368 set osd_esc_rpm_pos = 6242 set osd_esc_rpm_freq_pos = 128 set osd_core_temp_pos = 6505 set osd_stat_max_spd = OFF set osd_stat_battery = ON set osd_stat_min_rssi = OFF set osd_stat_max_curr = OFF set osd_stat_used_mah = OFF set osd_stat_bb_no = OFF set osd_stat_max_g_force = ON set osd_stat_max_fft = ON set osd_profile = 3 set debug_mode = GYRO_SCALED set scheduler_optimize_rate = ON set vtx_band = 5 set vtx_channel = 1 set vtx_power = 1 set vtx_freq = 5658 set vcd_video_system = NTSC set displayport_max7456_wht = 3 set frsky_spi_tx_id = 207,41 set frsky_spi_offset = -22 set frsky_spi_bind_hop_data = 0,30,60,91,120,150,180,210,5,35,65,95,125,155,185,215,10,40,70,100,130,160,190,221,15,45,75,105,135,165,195,225,20,50,80,110,140,170,200,230,25,55,85,115,145,175,205,0,0,0 set gyro_1_align_yaw = 1800 set gyro_rpm_notch_harmonics = 2 profile 0 # profile 0 set dyn_lpf_dterm_min_hz = 133 set dyn_lpf_dterm_max_hz = 323 set dterm_lowpass_hz = 100 set dterm_lowpass2_hz = 285 set vbat_pid_gain = ON set feedforward_transition = 30 set iterm_relax_type = GYRO set throttle_boost = 4 set acro_trainer_angle_limit = 40 set p_pitch = 85 set i_pitch = 30 set d_pitch = 75 set f_pitch = 45 set p_roll = 85 set i_roll = 30 set d_roll = 75 set f_roll = 45 set p_yaw = 95 set i_yaw = 30 set f_yaw = 45 set angle_level_strength = 110 set horizon_level_strength = 30 set horizon_transition = 80 set level_limit = 70 set horizon_tilt_effect = 80 set horizon_tilt_expert_mode = ON set abs_control_gain = 20 set d_min_roll = 0 set d_min_pitch = 0 set d_min_boost_gain = 0 set d_min_advance = 80 profile 1 # profile 1 set dyn_lpf_dterm_min_hz = 133 set dyn_lpf_dterm_max_hz = 323 set dterm_lowpass_hz = 100 set dterm_lowpass2_hz = 285 set vbat_pid_gain = ON set feedforward_transition = 30 set iterm_relax_type = GYRO set throttle_boost = 3 set p_pitch = 45 set i_pitch = 25 set f_pitch = 25 set p_roll = 45 set i_roll = 25 set d_roll = 38 set f_roll = 25 set p_yaw = 45 set i_yaw = 25 set f_yaw = 25 set angle_level_strength = 100 set horizon_level_strength = 30 set horizon_transition = 80 set level_limit = 75 set abs_control_gain = 20 set d_min_roll = 0 set d_min_pitch = 0 set d_min_boost_gain = 20 set d_min_advance = 100 profile 2 # profile 2 set dyn_lpf_dterm_min_hz = 0 set dyn_lpf_dterm_max_hz = 340 set dterm_lowpass_hz = 100 set dterm_lowpass2_hz = 200 set vbat_pid_gain = ON set feedforward_transition = 25 set iterm_relax_type = GYRO set acro_trainer_angle_limit = 30 set p_pitch = 45 set i_pitch = 25 set d_pitch = 50 set f_pitch = 25 set p_roll = 45 set i_roll = 25 set d_roll = 50 set f_roll = 25 set p_yaw = 45 set i_yaw = 25 set f_yaw = 25 set angle_level_strength = 100 set horizon_level_strength = 30 set horizon_transition = 80 set level_limit = 75 set abs_control_gain = 20 set d_min_roll = 40 set d_min_pitch = 40 set d_min_boost_gain = 30 set d_min_advance = 0 # restore original profile selection profile 1 rateprofile 0 # rateprofile 0 set yaw_rc_rate = 210 set roll_expo = 20 set pitch_expo = 20 set yaw_expo = 30 set roll_srate = 80 set pitch_srate = 80 set yaw_srate = 25 set tpa_rate = 30 rateprofile 1 # rateprofile 1 set yaw_rc_rate = 210 set roll_srate = 80 set pitch_srate = 80 set yaw_srate = 25 set tpa_rate = 0 set tpa_breakpoint = 2000 rateprofile 2 # rateprofile 2 set yaw_rc_rate = 215 set roll_srate = 0 set pitch_srate = 0 set yaw_srate = 10 set tpa_rate = 0 set tpa_breakpoint = 2000 rateprofile 3 rateprofile 4 rateprofile 5 # restore original rateprofile selection rateprofile 0 # save configuration save #
Posts: 189 Threads: 19 Likes Received: 20 in 12 posts Likes Given: 26 Joined: May 2019 Reputation: 1 profile 1 for 1S profile 2 for 2S, the rate are for acro, angle and acro los if I remember correctly.... but I don't remember which ones, try if you can like it • Posts: 9 Threads: 0 Likes Received: 1 in 1 posts Likes Given: 1 Joined: May 2020 Reputation: 0 Thank you soo much, its flying great! Sorry for beginner mistakes, that is my firs fpv drone and I'm so excited! • Posts: 189 Threads: 19 Likes Received: 20 in 12 posts Likes Given: 26 Joined: May 2019 Reputation: 1 04-May-2020, 07:28 PM (This post was last modified: 04-May-2020, 07:29 PM by Corrado-c.) for vtx depends, have you configured the port of vtx? (peripherals: VTX TBS smart audio in UART 2) and then in the part of "video transmitter" you have to load the VTX TABLE, download TBS SmartAudio Protocol (smartaudio 2.0) from here: https://github.com/betaflight/betaflight...VTX-tables EU or US versione. Although I think something should be seen even without these configurations ... then you have to check the cables ... • Posts: 189 Threads: 19 Likes Received: 20 in 12 posts Likes Given: 26 Joined: May 2019 Reputation: 1 oops, did I see wrong or did you have a problem with the vtx a few minutes ago? • Posts: 9 Threads: 0 Likes Received: 1 in 1 posts Likes Given: 1 Joined: May 2020 Reputation: 0 You right, I had a problem, figure out in bf the band was Race one, i compare default setting, change to boscam-a and is run perfect ? first fly on emax 450hv 5.15 boom. There is a higher angle for angle mod but still very stable when hovering around • Posts: 189 Threads: 19 Likes Received: 20 in 12 posts Likes Given: 26 Joined: May 2019 Reputation: 1 (04-May-2020, 07:58 PM)Marcin636 Wrote: You right, I had a problem, figure out in bf the band was Race one, i compare default setting, change to boscam-a and is run perfect ? first fly on emax 450hv 5.15 boom. There is a higher angle for angle mod but still very stable when hovering around I mainly use ACRO mode, in Angle I can't tell you. I'm glad you feel good there • Posts: 9 Threads: 0 Likes Received: 1 in 1 posts Likes Given: 1 Joined: May 2020 Reputation: 0 I'm grateful for it, it's fly amazing little bit crazy for beginner like me. Have you got the stock dump file for THs (I lost mine) , I know that I can download from Emax page but I read that couple people had some problem with it, so I'm looking for something out from quad • Posts: 190 Threads: 35 Likes Received: 39 in 30 posts Likes Given: 88 Joined: Oct 2020 Reputation: 2 I've had a TH2 for a while now running on the stock BF4.1 tune and never had hot motors. I've just resurrected the quad and decided to flash with BF4.2.6 and Jazz Mav ESC firmware so I could enable bidirectional dhot300 and all of a sudden hot motors. I simply added DMIN @ 60 and bingo this sorted it right away. Hope this helps others. My Facebook Page | My Youtube Channel iFlight Green Hornet 1 | Emax Tinyhawk Freestyle 2 | Emax Tinyhawk 2 ISDT 608 & Balance Board | Eachine EV800D | Taranis Qx7 | TBS Crossfire Mini v2 • |
