Threads: 65
Likes Received: 3 in 3 posts
Likes Given: 19
0 I had ESC #1 seem to die on my quad. BLHeliSuite showed that it was blank.
I bought a replacement, put it in today, but ESC 1 is still blank.
What could this mean?
Threads: 38
Likes Given: 430
118 25-Aug-2021, 09:10 AM (This post was last modified: 25-Aug-2021, 09:11 AM by kafie1980.) Is this an AIO or a separate ESC?
If a separate ESC board it maybe related to the wiring harness between the FC and the ESC. Check the connectors.
Maybe your previous ESC was not dead if its a connection issue.
The reason why I am suggesting this is because BLHeli relies on Betaflght passthrough and simply will not detect an ESC if the signal is not detected.
Threads: 172
Likes Received: 2,290 in 1,837 posts
Likes Given: 4,741
102 did you change anythingbin betaflight befor you had the esc issue? maybe anupdate with wrong formware target?
Threads: 65
Likes Given: 19
0 Thanks for the replies.
1. I have separate FC and ESC boards, not an AIO
2. I checked the wiring and everything is lined up right. I also checked continuity between the FC and ESC solder pads while the cable was plugged in between them and there is continuity for all the motor pads.
3. I'll try to tighten up the pins in the harness, though if I'm getting continuity between the pads on the FC and ESC, it should be connected correctly right?
Everything seems to be working except the one ESC/motor. Should I try directly soldering the wire for motor 3?
4. Nope, I didn't change anything in betaflight
Thx
Threads: 120
Likes Received: 835 in 680 posts
Likes Given: 134
20 … I would try direct soldering that particular esc/motor.. eliminating a “cable” issue. If the outcome is the same, you can try to “remap” that motor in the resources. If your fc only offers 4 motor outputs(pads) you can remap the LED pad (it has a “timer” -required for motors).
It’s not that hard..there maybe damage from the chip to the plug/pin that is not visible..
First make sure the esc and motor u are using is actually operating by installing it on a working pad….
Threads: 16
Likes Received: 176 in 149 posts
Likes Given: 26
8 Do you have another flight controller you could try the 4n1 ESC with?
