TBS unity 32 pro RED LED blinking
I have just bought a new one and I am trying to configure it. I have managed to unlock it but I have some issues, when I power it up and I am looking in the goggles, the video transmission works ok and after 5 seconds disappears, when I move the antenna the video is getting better but not as good as the begging.
In addition, the red LED blinks( I found on google that maybe the ground on the VTX is broken but I checked and it is okay.)
see below my configuration:
Any suggestions? as I have spent more than 3 hours on this matter without any luck.
EDITED:
After I disabled Betaflight VTX setting to none works okay.
Attached Files Thumbnail(s)
sounds like it was set to "pitmode" in betaflight vtx tables.
smartaudio over the fc would alow you to settup a cannels bands and lower ofer the configurator or over betaflight osd.
if you wont like to use that, you are fine. if you would like these options, i beleive it would be a settup issue.
what betafight version do you use?
(02-Nov-2020, 01:26 AM)hugnosed_bat Wrote: sounds like it was set to "pitmode" in betaflight vtx tables.
In my betaflight configuration, I had removed the PIT mode, it looks very strange. I will need to investigate more.
I am using version 4.2 configurator 10.7.0
did you install the vtx table for your unify?
i had an issue a few times, it allways started in pitmode, i dont know why that was.
i would power the quad, get into the osd settups with the tansmitter (short discribed at boot up); featers/vtx sa/
than check if pitmode is set to "off"
or change the powerlevel manualy
go to set: "yes"
have a look if you can getout of pitmode with this way
(02-Nov-2020, 10:35 AM)hugnosed_bat Wrote: did you install the vtx table for your unify?
go to set: "yes"
thanks very much for your help. Sorry, how can I install the table for unify?
Please find attached the picture with the settings. Please advise if I have done something wrong.
FC: MATEK F7 22SE.
Anyone who can help with this matter?
(06-Nov-2020, 03:36 PM)JohnBos Wrote: Anyone who can help with this matter?
Run the following block of commands in the CLI to set up your VTX tables correctly for the TBS Unify Pro32 HV...
vtxtable bands 5
vtxtable channels 8
vtxtable band 1 BOSCAM_A A FACTORY 5865 5845 5825 5805 5785 5765 5745 0
vtxtable band 3 BOSCAM_E E FACTORY 0 0 0 0 0 0 0 0
vtxtable band 3 FATSHARK F FACTORY 5740 5760 5780 5800 5820 5840 5860 0
vtxtable band 4 RACEBAND R FACTORY 0 0 5732 5769 5806 5843 0 0
vtxtable powerlevels 4
vtxtable powerlabels 25 100 400 1000
vtxtable powervalues 14 20 26 30
save
  • JohnBos
(06-Nov-2020, 04:59 PM)SnowLeopardFPV Wrote: Run the following block of commands in the CLI to set up your VTX tables correctly for the TBS Unify Pro32 HV...
vtxtable bands 5
vtxtable channels 8
save
Thanks, SnowLeopardFPV it worked by changing this line vtxtable powerlabels 25 100 400 1000
to this: vtxtable powerlabels 25 100 400 1w
not sure why, but it works now. thanks very much.
(06-Nov-2020, 09:24 PM)JohnBos Wrote: Thanks, SnowLeopardFPV it worked by changing this line vtxtable powerlabels 25 100 400 1000
Hesitant to bump an old thread, but I wanted to point out that the issue here is that vtxtable powerlabels are limited to three (3) characters. So '1000' is not a valid powerlabel, but '1W' is.  Hopefully this helps someone out!
(06-Apr-2021, 05:18 AM)V-22 Wrote: Hesitant to bump an old thread, but I wanted to point out that the issue here is that vtxtable powerlabels are limited to three (3) characters. So '1000' is not a valid powerlabel, but '1W' is.  Hopefully this helps someone out!
Yes, that is correct. I wasn't aware of the 3-character limitation at the time of writing my original reply. It would be a simple task for the Betaflight developers to increase the limit to 4 characters which would then better support some of the newer high powered VTX's such as the Rush Tank Solo which can go up to 1.6W. Unfortunately with the 3 character restriction you can't specify either 1.6W or 1600, so the best you can do is put 1W+. I guess it wouldn't be on the top of their priority list to make that change.
  Skyzone 04O PRO goggles SeismicCWave 34 2,211 02-Jun-2024, 06:10 PM
Last Post: SeismicCWave
  TBS Unify Pro32 HV and SpeedyBee F405 issues Shoto 5 413 02-May-2024, 11:17 PM
  TBS Fusion vs Rapidfire vs Speedybee VRX modules at same price, which is best? Luk5569 21 1,715 09-Apr-2024, 09:03 PM
  Announcement TBS Fusion 2.34 (Beta) Firmware Released SnowLeopardFPV 10 5,579 06-Mar-2024, 01:27 AM
  TBS UNIFY Pro32 zomer 5 410 27-Feb-2024, 10:02 AM
Last Post: cst3x6
