Switch setup on Spektrum DX6
Hello,
I bought a Diatone 2019 GT R349 HD MK2 Edition, it is setup and ready to go but I am trying to setup other switch functions on the DX6 remote but I just can’t figure out what I am doing wrong. For example, I want to setup the buzzer on switch F. I just put the AUX to auto in Betaflight for the buzzer and flip the switch F but it doesn’t pick it up in betaflighf. Gear is on switch H for arming and Aux1 is on switch B for the flight modes. How can I configure the other switch if the Auto in betaflight is not working?
Thanks!
I am not familiar with Spektrum. But most radio is similar. Learn how to assign the switch you want to the channel in the radio. Once you have that setup, you will know which AUX is assigned to which switch. Basically the first 4 channels are for throttle, aileron, roll and elevator. Then 5th channel is AUX 1.
http://www.manualsdir.com/manuals/428995...ml?page=16
You only have 6 channels in a DX6, that's all you are going to get. Maybe loose a flight mode and set it up as third position on AUX?
I see. Thanks for the answer!
  SpeedyBee Not Talking to Spektrum Receiver BobMaine 7 2,455 20-Jun-2024, 10:01 AM
  How do you setup switches in edgeTX when you ran out of buttons? alfonz19 19 563 04-Jun-2024, 02:52 AM
Last Post: Radworm
  Can you have 6 position switch default at one position? changitamir 0 89 30-May-2024, 11:17 PM
Last Post: changitamir
  Need recommendation for FPV setup butchalline 7 236 24-Mar-2024, 02:35 PM
Last Post: iFly4rotors
  Boxer SA Switch will NOT Arm my Quads soky157 35 1,380 01-Mar-2024, 12:29 PM
