22-Feb-2024, 10:15 PM
My Boxer WILL arm my Quads using the SB, SC & SD Switches. The SA Switch will NOT Arm my Quads.
Any ideas?
soky157
Any ideas?
soky157
Boxer SA Switch will NOT Arm my Quads |
22-Feb-2024, 10:15 PM My Boxer WILL arm my Quads using the SB, SC & SD Switches. The SA Switch will NOT Arm my Quads. Any ideas? soky157 22-Feb-2024, 10:30 PM There isn't enough information provided to give you a clear answer. Is your SA switch assigned to an output channel on your BOXER in the INPUTS and/or MIXER pages for the model? 22-Feb-2024, 11:13 PM Does that switch actually “work” ? Assign it to something and see if it show activation in betaflight modes tab.. if it doesn’t .. you may need to disassemble it and check if with a meter.. better yet.. see if u have activation in the screen on the controller.. 23-Feb-2024, 01:06 AM I didnt think of those things. I will check those things and get back. Thank you. soky157 23-Feb-2024, 01:30 AM Let me better explain how I set the SA Switch up. In BFC in Modes Tab, I set the ARM Aux Switch to Auto, then I flipped SA Switch and it went to AUX 3, I believe. This is how I tested the other Switches. I also moved the ARM slider to 1850-2100. The Drone Armed on all the Switches except Switch SA. I hope that better clarifies my actions. soky157 23-Feb-2024, 02:26 AM So i'm unsure from your description whether your radio is setup incorrectly or you are doing something wrong in Betaflight. Also is this ELRS or something else. If the Radio is setup incorrectly you can remap it in EdgeTX. So if that switch works, but is assigned wrong, you can change the channel it uses. Normally you never have to do this because the radio comes preconfigured from the factory, but sometimes things go wrong or maybe it was wrong to start with. On my radio I snapped the SD Card while removing it and then had to redo my radio from scratch, including assigning the buttons to channels. Which taught me a ton about EdgeTX. You might want to do this yourself for the learning experience and while you are at it learn about telemetry and how to use telemetry to get info about your quad via the Radio. This basic video will teach you how to map a switch in EdgeTX. Then assign arm to AUX1 which should be your SA switch on CH5, in Betaflight. https://www.expresslrs.org/quick-start/pre-1stflight/# If the problem is something else or not ELRS. You need to be a bit more verbose about the problem, because I don't think we have enough info to advise you. Try Not, Do or Do Not - Yoda 23-Feb-2024, 08:45 PM Sorry all the Drones are ELRS. 23-Feb-2024, 09:03 PM Hello these are pictures of my Boxer INPUTS and MIXES pages. 23-Feb-2024, 09:20 PM (This post was last modified: 23-Feb-2024, 09:25 PM by SnowLeopardFPV. Edit Reason: Added "EDIT" line. ) From the photos it shows that you haven't assigned the SA switch to any of the output channels. That is why the receiver and Betaflight aren't able to see or detect that switch. Configure / assign the SA switch to one of the spare auxiliary channels on your Boxer and it will then work. EDIT: Have a watch of Drainman's video linked to below which shows how to assign switches to auxiliary channels. He's using a different transmitter than you, but the procedure is exactly the same on a Boxer... 23-Feb-2024, 09:35 PM If you are running ELRS you need to keep the arm on AUX1 (CH5). If you want to use your SA switch, you can remap CH5 under the MIXES tab to SA switch. Double-check in BFC you have set the correct range according to your switch positions (the arm mode will light up when the switch is in arm position). 23-Feb-2024, 09:51 PM (This post was last modified: 23-Feb-2024, 09:52 PM by Pathfinder075.) Change: CH5 - SB to CH5 - SA. CH6 to SB CH7 to SC CH8 to SD and anything else on to the next available channel. That should fix your issue with SA and not arming. Looks like everyone else got there first. Try Not, Do or Do Not - Yoda 24-Feb-2024, 07:33 PM I adjusted the INPUTS OUTPUTS and MIXES are below. Boxer, still does not give me the option to use SA Switch to ARM the Drone. Also, in BFC Modes Tab when I flip the SB Switch it make the ARM Mode turn Red instead of the SD Switch I had to set for ARM! 24-Feb-2024, 07:47 PM (This post was last modified: 24-Feb-2024, 07:50 PM by Pathfinder075.) It's still wrong. It needs to be like this. Inputs Code: Rud 100 Rud Mixes Code: CH1 100 IAil Leave OUTPUTS as default. ARM, MODE, TURT, BEEP are descriptors, change them to what you want. But ARM has to be on CH5. Whatever switch you assign to CH5 is your ARM switch. Try Not, Do or Do Not - Yoda 25-Feb-2024, 12:54 AM Thank you so much for sticking with me thru this. I will follow your most recent reply and get back. soky157 25-Feb-2024, 09:01 PM Hello again. I set the INPUTS and MIXES exactly as you indicated. Strange things are happening now. The Boxer throttle now DOES NOT cause the Bars to move in Receiver Tab in BFC. Also, the SA Switch is not listed as an option in Inputs and Mixes. So I chose the SD Switch as the Arming Switch as well as SB for Angle, SC for Turtle mode. While in Modes Tab the SD Switch DOES NOT Activate the ARM box...instead it is the SB Switch all the down that Activates the ARM Switch. Pushing the SB Switch to the Middle Activates the ANGLE Mode. Totally confused! soky157 |
Radiomaster Boxer Trim Switches | soky157 | 2 | 153 | 21-May-2024, 11:51 PM Last Post: soky157 | |
same arm | Eyes.fpv | 1 | 127 | 06-May-2024, 08:49 PM Last Post: SeismicCWave | |
No OSD, Converted analog to HDZero Quads | FPVme | 14 | 384 | 24-Mar-2024, 08:35 PM Last Post: Rob Axel | |
Can't get drone to arm | dirtydave | 3 | 323 | 02-Feb-2024, 05:22 PM Last Post: mstc | |
Drone doesn#t arm | janpme | 1 | 243 | 06-Dec-2023, 04:32 AM Last Post: hugnosed_bat |
