Threads: 12
Likes Received: 4 in 4 posts
Likes Given: 1
0 The motors sound a little choppy, almost like it's hitting something, but I've checked and there's definitely nothing the props could hit. Could this be oscillations/vibrations? The sound is similar to a grinding, and usually happens close to the ground (propwash maybe?) and how can I fix this?
Threads: 587
Likes Received: 8,962 in 6,632 posts
Likes Given: 1,425
787 Make sire the props are on tight and can't move on the spindle. Also make sure the LiPo balance lead is strapped/secured properly to stop it flailing into the prop blades.
Are you running the default Betaflight tune or have you messed around with any settings? And are you runing bi-directional DSHOT (for RPM filtering)?
