Threads: 203
Likes Given: 306
11 Is there a way to stop arcing when plugging in LiPo?
The male pins and female pins turn black in time and the generic xt60 plugs can loose connection in flight.
Threads: 585
Likes Received: 8,958 in 6,629 posts
Likes Given: 1,425
786 You can get anti spark connectors but IMO it's not really worth it. It will take a long time for the XT60 connections to come loose or fail. The LiPo will probably die before that happens. My 2 year old LiPos still work absolutely fine and still have a tight connection even though the metal connectors have clearly oxidised over time due to the arcing.
Threads: 203
Likes Given: 306
11 I’m trying dielectric grease but also I stopped using generic xt60 plugs.
The generic don’t have alignment slots and can bend male prongs with x pattern cut into it.
My ChinaHobbyLine packs started making motors act up and once I cut off POS connectors they are now fine.The connection got so loose the plug came completely out on a bumpy landing but not hard enough to move LiPo.
I couldn’t figure out why drone flew great using Tattu packs but ChinaHobbyLine packs caused irratic motor performance and when it came unplugged it was obvious.
Amass plugs are made to tighter tolerances and worth the extra cost.
One 0.25 cent POS plug crashes a 500 drone.
Threads: 585
Likes Given: 1,425
786 All the XT60 connectors I use are AMASS branded ones. I just checked my Tattu LiPos and they also have AMASS connectors fitted. So I guess that is why I never had any issues, because all my kit is using a decent brand of connector. I've never suffered any loose fitting connector issues.
Threads: 392
Likes Received: 3,231 in 1,827 posts
Likes Given: 3,214
101 That arcing freaks me out every time. Also a big fan of the AMASS but more so for their "grip" clasps that also serve to cover the wires. Makes disconnecting much easier.
Threads: 203
Likes Given: 306
11 Now that I know it’s the POS plugs causing erratic motor behavior I won’t be using them again.
Imagine not knowing it’s the plug and trying to track down problem.
