Speedybee F7 V3 BMI gyro issues
Hi - I decided to give the new Speedybee F7 V3 a try because everyone talks about how quiet the gyro is at low frequencies. Which it is. However, I seem to have a strong peak of noise just on the pitch axis at 136hz that is getting through the default filters and pids. Think this is a gyro issue? Roll axis is clean. If it were a build issue it should affect all axes right?
Running BF 4.3, default pids and filters and rpm filter is on. Should I just lower my dynamic notch frequency and give that a try or RMA this FC?
Solved this by adding 2 dynamic notches with a Q of 400 and lowering min threshold to 100hz. Noise gone and prop wash is no worse with extra filtering that I can discern.
  Speedybee F405 v3 blackbox error BF4.5 az.lonewolf81 2 95 30-Jun-2024, 12:19 PM
  SpeedyBee F405 V3 Testing Motors (Not Spinning) angent56 20 3,029 07-May-2024, 02:53 PM
Last Post: mstc
  Avoid the updated JHEMCU GHF420AIO with the ICM42688-P Gyro Recursion 19 3,441 08-Mar-2024, 09:33 AM
Last Post: swequad
  Announcement PSA: BMI270 Gyro - Hardware / Tracking Issue SnowLeopardFPV 25 1,776 07-Feb-2024, 02:39 PM
Last Post: Luk5569
  Gyro Filteration marv23 5 291 16-Jan-2024, 12:53 PM
Last Post: marv23
