Source V mod project
I have always appreciated the rigidity and good flying characteristics of the TBS Source V frame.  Unfortunately, it is really limiting when you want to put a DJI Vista and gps on it, real sma antenna + trying to shoehorn a GoPro on it.
After looking at the design, I made 4 new parts that replace the top and bottom sections of the frame + 2 new braces and 2mm standoffs to provide a forward mounting location for the camera that isn't completely obscured by the props like the stock design.   The added benefit is I will be able to design a 4 screw-mounted tpu base for a full-sized camera.
 It was interesting cutting out the interlocking sections for the vertical legs- I had to use a 1mm PCD(poly crystaline diamond) coated cutter to make the tiny cutouts.  Here are a few pics:
Parts:
[Image: se4tqAxl.jpg]
Right of the machine:
[Image: 1SoK3IDl.jpg]
Close up of the cutout fitment for the leg
[Image: hqPagL4l.jpg]
rendering showing prop clearance for the camera
[Image: i387Qusl.jpg]
Any suggestions would be appreciated...
[-] The following 2 users Like gt40's post:
  • Lemonyleprosy, the.ronin
One more pic of the assembled frame:
[Image: Z0HCSa2l.jpg]
[-] The following 1 user Likes gt40's post:
  • the.ronin
I don’t have any suggestions, but it does look awesome. Big Grin
Dangerous operations.
Update,  finished the build and successfully did my first flight.  This was my first attempt at building something that is focused on max speed above all else.
Major components were:
Iflight f7 Blitz mini stack 55 amp
KO DEMON SEED CRYO 2208 2540KV motors. FYI, measured 1850 kg per motor on a thrust bench test in this short test video:
Master screw 5x4.5 biprops(training wheels because I haven't flown this fast before)
vista and nebula pro
crossfire nano
matek M8Q-5883
iflight long range antenna
Tattu R-Line 1550 mah 6s
Overall, I am really happy with the mod.  It is ridiculously stiff and now has enough real estate to properly mount stuff while being lightish at 80 grams for the full frame.
The first flight was very humbling...  the craft is so over- powered that at first I thought it might do a fly away because any throttle stick and it just jumps.  i dropped the throttle and it drops like it should so after a few laps around the house I found it was surprisingly flyable.  I will definitely need to find some open space to test this guy out and learn how to fly at a 50 degree angle or so.  Kudos to John at addictive RC for sharing his settings for blheli to keep things from overheating or de-syncing and advice on the motors.
I have a custom tpu gopro mount printing so I hope to share some video at some point if I can fly it at full speed without crashing.  Considering the power to ratio of this thing with 4x 1850kg worth of thrust, it should be a rocket...
[Image: w4WWtQ4l.jpg]
[Image: 1FUpG1Kl.jpg]
[Image: ohtPn5ol.jpg]
  • Lemonyleprosy
  Build RDQ Source One v4 relentlesstech 9 724 08-Aug-2022, 11:51 AM
Last Post: iFly4rotors
  Build RDQ Source One V3 Lemonyleprosy 53 3,730 15-Nov-2021, 09:41 PM
Last Post: Lemonyleprosy
Exclamation Bugs3 Project Revisit PIDS and Hoover video added BF 4.1. F4 FC with JESC ESC rolo95 95 8,790 10-Jun-2021, 02:06 PM
Last Post: rolo95
  Project: Sepukku the.ronin 75 4,313 13-Mar-2021, 09:10 PM
Last Post: the.ronin
  Help TBS source v3 or v4 Yelreppa 2 2,521 12-Feb-2021, 03:38 PM
Last Post: Yelreppa
