[SOLVED] Frsky X9 Lite - How to setup Battery low voltage and RSSI low audio warning.
(24-Apr-2023, 06:25 PM)SnowLeopardFPV Wrote: For logical switch L07 (the timer), add an AND value for the arm switch when it is in the ARM position. You can see that in my post at the link below where I have "SF↓" specified (I use the SF switch for arming). Make sure you use the cirrect direction arrow depending on whether the switch on yours is up or down when armed. Note that my timer is on logical switch L06 in that example...
https://intofpv.com/t-first-quad-purchas...#pid172256
Thank you. That fixed 1.75V readouts when quad not armed or connected to BF.
0V still read out once, when radio power on. That's not big deal for me.
Yeah. Oscar's configuration isn't foolproof which is exactly the reason why I created my own variation with some changes in. It took a little bit or trial and error to get everything working exactly the way I wanted it to, and without voltages being read out when they shouldn't be. My setup doesn't read out ZERO volts when I switch on my transmitter.
If you want it working the way mine does then just set it up exactly the same way as I did, See that other post again HERE. If you don't want to mess up what you already configured then just copy your current model to a new one by long pressing the scroll wheel on the model you want to create a duplicate copy of and then select "Copy". Then after you are done you can delete whichever of the two models you no longer need.
  • sim_tcr
  ELRS Module with Taranis X Lite NYCDiesel 14 413 17-May-2024, 10:56 PM
  Spectrum USB programmer to update Frsky rx? baevans11 8 390 23-Apr-2024, 01:24 PM
Last Post: baevans11
  Help Frsky XM+ Firmware versions Steak-9 3 252 26-Mar-2024, 01:28 PM
Last Post: Steak-9
  Help FrSky r xsr receiver not entering bind mode August 1 178 05-Mar-2024, 08:49 PM
Last Post: August
  [Solved] Don't get any input from ELRS receiver in BetaFlight aprudnikoff 4 454 03-Mar-2024, 01:03 AM
Last Post: aprudnikoff
